Remove these ads by
Signing UpStep 1: Build a grating support inside the garbage can
Next, you need to build supports for the grating. Using a 3/8" drill bit, drill three holes approximately 8" below the top of the garbage can, equidistantly placed around the circumference of the can. Then slide three 3" x 3/8" bolts through those holes and secure with a corresponding washer and nut. This will be used to hold the grating up while allowing the grating to be easily removed.
Visit Our Store »
Go Pro Today »
Not only that, but there really is nothing sustainable about going to the local HD and buying a brand new garbage can to make a homey-style smoker. The idea is kind of neat, but the fact is that these inventions came out of poverty, not because someone said, "Hey cool! Let's go buy a garbage can make a smoker!"
I've got two Weber grills and I didn't pay more than ten bucks for either one. One is a medium sized one and the other is a classic red extra-large one enough for a party. Any container can be converted into a smoker, but why not start with something made to withstand high heat and that has some ventilation holes and go from there?
Also, buying used is the most sustainable and real way to "keep it local" and keep more things out of the waste stream and back into service.
After that you have a pile of goo - why don't people look things up
The bin is galvinized so other things might be added to it aswell like lead since it wasn't meant to cook anything but just for rubbish.
Here's a quote from wiki:
The process of hot-dip galvanizing results in a metallurgical bond between zinc and steel with a series of distinct iron-zinc alloys. The resulting coated steel can be used in much the same way as uncoated. Galvanized steel can be welded; however, one must exercise caution around the resulting zinc fumes. Galvanized steel is suitable for high-temperature applications of up to 392 °F (200 °C).
So unless your planing on keeping the temp below about 350 F your most likely not going to get to your next thanks giving dinner. All my smokers can reach that easy and if your thermometer is faulty watch out.
Try using a beer keg it's out of of 304 food grade steel i made one of those and it can fit a turkey and am going to make a drum smoker out of 316 stainless aswell soon
http://www.chemicalelements.com
Symbol: Zn
Atomic Number: 30
Atomic Mass: 65.39 amu
Melting Point: 419.58 °C (692.73 K, 787.24396 °F)
Boiling Point: 907.0 °C (1180.15 K, 1664.6 °F)
Number of Protons/Electrons: 30
Number of Neutrons: 35
Symbol: Pb
Atomic Number: 82
Atomic Mass: 207.2 amu
Melting Point: 327.5 °C (600.65 K, 621.5 °F)
Boiling Point: 1740.0 °C (2013.15 K, 3164.0 °F)
Number of Protons/Electrons: 82
Number of Neutrons: 125
commented over 2 years ago on this
Why shouldn't you drink the rain water collected from a zinc coated garage roof
Even if it's not going going to get hot to the point of melting in the sun fine particals of the coating will come off and same goes for any type of zinc coated cheap rubbish bin - because it's not food grade people since things like this can easily contaminate the food but who knows you might be lacking zinc in your daily diet then go for it
Serg
my painted version
Bottom
Grates in the "smoker" position
The one thing that bothers me (as a welder) is that all the metal hardware used here except for the grill rack itself is zinc plated. I'm constantly on the lookout for zinc fume fever, but this may be OK here because you are not using actual fire, nor allowing the food to contact the sides.
Anyway, here's an case of do-it-youself zinc fume fever, although an extreme one. Keep in mind that exposure is clumative.
http://www.anvilfire.com/iForge/tutor/safety3/index.htm
Other than zinc, hexavalent chromium is sometimes used as an anti corrosion coating (another thing you don't want to eat :P). Not to mention, if there's a weld seam, you risk other potential nasties from that. You're best bet is to cook the crap out of the can before using it the first time to remove any coating ;) The general consensus is that you'll probably be okay - but who wants collateral damage from their holiday meal? Technically, fish from the Everglades is okay (except for high mercury levels o.0)
We used to do something similar when I was a little kid in boy scouts :P It's a whole lot of fun - probably because of the novelty factor :P
