3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Garbage Can Turkey Smoker
Step 5Prepare wood chips and get ready to smoke
prepare wood chips and get ready to smoke
Actually finding enough woodchips might be tricky. For a turkey, we recommend applewood (or pecan, if you can find it), but oak and hickory would work in a pinch.
You want to soak the chips for at least 20 minutes prior to smoking, but there is no real upper limit. Get a pan that you don't mind destroying that's small enough to fit between your two threaded rods, about the size of the hotplate, and at least a couple inches deep.
Fill the pan with chips and move the can to a safe location, far from any buildings, but shielded from the wind if it's cold out. Obviously, the smoker will generate a lot of smoke, so you might want to keep it away from open windows/doors as well.
You should also have appropriate safety equipment ready, namely heat-resistant fingered gloves and a fire extinguisher. Still, the ambient temperature you are generally shooting for is around 230F, so the risk of fire is very low.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:drEel
