I love to eat Indian and Central Asian naan.
My genius friend Dave Bauer of the Farm and Sparrow bakery near Asheville, NC sent me this video a while ago and I started baking naan immediately. (There is no chance I'll ever be as cool or as skillful as the woman in the video, but there's no reason not to trail distantly behind her.)
I have been baking naan on a pizza stone in my electric oven (turned up as high as the oven will go) for a year or so with decent results. When I saw John List's flower pot tandoor I knew I had to build one.
It took fifty bucks and a couple of hours, and it works! It will take a while to get control of shaping, heating and timing, but the (homely) results are already delicious!
Whether or not you build this oven, you should run out and buy Flatbreads and Flavors by Jeffrey Alford and Naomi Duguid because it will immediately make you a happier person.
-Fritz
http://knaveoftarts.com
Remove these ads by
Signing UpStep 1Garbage Can
I have an old galvanised purpose build garden incinerator. Would it be safe to use such a product? I'd expect this to be a safe product to use, but would like your insight.
I can't take credit. It's John List's design.
> could I not just get a baking stone, put it on a grill, and bake my naan that way?
Absolutely. I do that at least weekly. You want to use a fairly thick baking stone or risk having it shatter. (Ask me how I know this.) I use the same trick for pizza and focaccia. For loaf breads I use a preheated clay dome over the preheated stone: 9/1/2010 Sourdough
> Do you think that there will be a flavor difference?
There are a bunch of subtle differences due to intensity of heat, distance to heat, direction of heat and ratio of convective vs. radiant heat, but the convenience of the stone-on-grill method makes it superior unless you have plenty of time or are showing off for a crowd.
For a single batch of naan, I use 3c all-purpose flour, small handful kosher salt, small handful yeast, mix that all up and then pour in buttermilk while stirring until it forms a nice wet but not quite sticky dough. I knead it well, then let it double, then roll out tangerine-sized rounds to a generous 1/4" thick on baking parchment, poke a bunch of holes in the center of each loaf with a fork, and transfer the dough-with-parchment to the stone using a cookie sheet as a peel. Takes a couple of minutes to bake on a really hot preheated stone, longer on a cooler or poorly preheated stone. I never get good blistering on the grill because most of the heat is coming from below. The tandoor, stone-under-broiler and cast-iron-skillet-under-broiler methods give you better blistering. Sometimes I brush the finished loaves with melted butter or ghee.
I could make one, but I would love one from Uzbekistan, if we can work out a barter arrangement.
