3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Garbage Can and Flower Pot Tandoor Oven
SAFETY UPDATE: You should not do this with a galvanized can! If something goes wrong (too much airflow, too little insulation) the outer can could exceed 1,000DegF and the zinc (that's the "galvanized" part) could vaporize into a toxic gas! Avoid galvanized! Thank you vigilant commenters!
I love to eat Indian and Central Asian naan.
My genius friend Dave Bauer of the Farm and Sparrow bakery near Asheville, NC sent me this video a while ago and I started baking naan immediately. (There is no chance I'll ever be as cool or as skillful as the woman in the video, but there's no reason not to trail distantly behind her.)
I have been baking naan on a pizza stone in my electric oven (turned up as high as the oven will go) for a year or so with decent results. When I saw John List's flower pot tandoor I knew I had to build one.
It took fifty bucks and a couple of hours, and it works! It will take a while to get control of shaping, heating and timing, but the (homely) results are already delicious!
Whether or not you build this oven, you should run out and buy Flatbreads and Flavors by Jeffrey Alford and Naomi Duguid because it will immediately make you a happier person.
-Fritz
http://knaveoftarts.com
Step 1Garbage Can
Garbage Can
Your basic brand-new thirty gallon galvanized garbage can. This is just an arbitrary fireproof container and has no role in cooking.
103 comments
1-40 of 103next »
Mar 23, 2012. 9:02 AMbp123 says:
What did you do to protect this from rain? I was thinking about keeping mine covered during non-use with the lid that comes with the drum. And keeping it inside the garage during the winter. You think that wud deter cracking? Thanks again
Mar 22, 2012. 8:49 AMbp123 says:
Using your design, Im gonna be using a 30 gal steel drum too but it still has paint on the outside, not heat resistant. How hot does the outside of your can get? Do you think I should strip the paint or do you think it wont get hot enough to melt it? Thanks
Mar 22, 2012. 10:12 AMbp123 says:
Isn't it safe to assume that pots that are made today will not have lead?
Mar 23, 2012. 6:51 AMbp123 says:
Actually I'm seeing some sites talking about lead in terracotta. I guess I will ask the company and do the test myself
Mar 23, 2012. 8:12 AMbp123 says:
I called a company called Deroma which sells terracotta pots to Home Depot. No lead usage in their pots.
Dec 6, 2011. 9:54 AMjallan5 says:
I was thinking of doing this, but there are also toxicity issues with commercially made clay pots as well. One common source is China where lead is an issue. You should look for some kind of food grade clay pots, like Tagine and rice cookers. These are more expensive, but worth it not to have lead leeching into your food.
Apr 30, 2009. 4:13 PMferrous says:
You should probably know that you should completely burn off the galvanization from the can before you actually cook in it. If you see that thick, curling white smoke coming from the galvanised parts, don't inhale it! It's poison. This is why welders dont like to work with galvanised metal, and neither should cooks ;)
May 5, 2009. 8:25 AMjustafew says:
I would love to get my hands on 2-3 un-galvanised cans for "turkey in a can" right now we are using a very large terracotta pot but it limits the size of the bird we can cook. Can find untainted cans at the hardware store...any thoughts?
Nov 9, 2011. 4:10 AMjackhg says:
call a galvanizer, who actually dips the steel buckets, maybe they can tell you where to get the cans, they might even have some rusted ones
May 21, 2009. 9:10 AMchuckr44 says:
Get a painted bucket at Big Lots, then burn off the paint (build a bon fire around and in it). How's that? But that's only a summer item and they are running out fast.
May 4, 2009. 6:03 PMpaddlesport says:
Zinc melts at approx. 900 F. Vaporizes at approx. 1200 F. Not likely to occur in any cooking process I am aware of. Bake on!
May 5, 2009. 5:49 PMferrous says:
Although, I forgot to add that I really like your design otherwise :)
May 4, 2009. 6:19 PMferrous says:
Actually, there are alot of wood fired pizza ovens that can get to 1000 F and beyond. Its really quite easy for the occasional hot-spot to reach those temperatures. I wouldn't personally use a zinc plated can, is all. That stuff's nasty.
Aug 24, 2011. 2:54 AMAli_Jay says:
You mention about not using a galvanised steel container.
I have an old galvanised purpose build garden incinerator. Would it be safe to use such a product? I'd expect this to be a safe product to use, but would like your insight.
Oct 4, 2010. 12:34 AMhamstanz says:
how would you go about emptying the ash ?
Sep 5, 2010. 6:30 PMhandyman05 says:
I think that this is an amazing project and shows an amazing amount ingenuity and creativity. However, could I not just get a baking stone, put it on a grill, and bake my naan that way? I have heard of people doing it that way if they did not have the Tandoor oven or the obvious creativity that you display here. What are your thought about doing that vs. using your method? Do you think that there will be a flavor difference?
Sep 6, 2010. 1:54 AMhandyman05 says:
Thanks. I will keep that in mind the next time that I am trying to make some naan. There is a Himalayan resturant that I go to and they have very tasty naan. Also, thanks for the way that you answered my questions. Helped my brain absorb the information better. Happy naaning? I guess baking would be better, but since we were all referring to naan and how to make it using this kind of oven, naaning sounded cooler.
Jun 8, 2010. 3:18 AMRajabbek says:
Good project! I live in Uzbekistan, and yet no where did not see that someone had tried to create such minitandyr. Wizards, in preparing the clay for tandyr add back down from head rushes. Tandoor should not be conical and slightly oval and narrowed at the neck. Landscape with a throat tandyr set up mainly Turkmen. And Uzbekistan
Jul 4, 2010. 11:03 PMRajabbek says:
Hello Thank you for your feedback on my comment. I must confess that I do not speak English, and translate the texts of comments from Russian into English using Google translator. Despite this I really liked your project. As chekich, I do not understand what it is, can you know the name of the Uzbek? On the Uzbek is a verb Chekmok, which means smoke.
Jun 16, 2010. 8:23 PMmacrumpton says:
It seems like you could sidestep the problems of the toxic galvanized metal by just making your own enclosure out of some sheet metal. Since it does not get that hot I think using aluminum flashing (available at most hardware stores) and a few nuts and bolts or pop rivets would give you a perfect metal tube that you could size exactly to the flowerpot.
Jun 18, 2010. 2:15 PMmacrumpton says:
When I read the instructable again I was struck by the cost of the metal can. To get a 10' roll of aluminum flashing 2' wide is about $15 in the expensive hardware store near me, and if you could find a printer that is tossing aluminum printing plates you could get it for free. Another cool thing about using the sheet metal is that you could make your container other shapes besides a cylinder, so if you wanted the top of your oven to have some counter space you could make it a truncated cone (point down).
Jun 8, 2010. 8:03 PMrobertblacksmith says:
one of my tandoori cook books,which of course i can't find, opening chapter is on the history and making of tandooris.in India they don't turn them on a wheel but start them as a flat sheet of thick river clay which they roll into a tube wet the edges and work the clay tell there is no seam . stand it up right and work the top of the tube tell i forms a cone shaped top. all being made at the craftsman's shop were open topped. it allso was interesting that the inventory on the shelves behind them. many clay oven alone but half where in metal barrels. also because my head is full of useless information. lead was used as a coloring agent in pottery glaze before the danger was found and was band in most places.
Jun 10, 2010. 11:04 AMrobertblacksmith says:
"Tandoor: The Great Indian Barbecue " by Ranjit Rai amazon has copy's but be warned it is a spend y book.Ranjit Rai other books are great too.
Jun 7, 2010. 7:28 PMrickym says:
This is good for here and there but here is the problem, the pot that you use can not stand very high heat for long. (We made one and it broke after after a little while but then again we did use it in a restaurant). You would be better off digging a hole and lining it with heat proof bricks. If your concerned about bugs getting, use a mixture of concrete & clay and line the hole with it, and let that harden, and then lite a fire in the hole to let the clay harden.
Jun 7, 2010. 9:52 PMrickym says:
ture but if you set your bricks in a pyramid shape or to be more ture a circular shape and line it with the concrete & clay mix you would be alot better off plus you can get the heat much much higher giving your chicken a crispper skin while staying tender in the middle but hey whatever flots your boat my dad is a cheif so i get my naan and tandoori fix anytime i want =D
1-40 of 103next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
21
Author:fritz.bogott
Fritz Bogott writes bread and bakes stories in an oak savanna just outside Northfield, MN.
