My papaya tree is flourishing so are other plants (note: do not overuse).
Mix Garbage Enzyme with my shampoo so that the toxic chemicals are neutralized by the Garbage Enzyme.
Take out foul odors from toilet - only bleach comes close and as fast as Garbage Enzyme.
Mix also with floor cleaners as we have a 'stockpile' of floor cleaners so have to use it all; floors are squeaky clean.
Garbage Enzyme can be used as an alternative to bleach and other cleaning compounds.
It can effectively used as:
- as a household cleaning liquid
- to remove foul odors, molds and grime in the kitchen and toilet
- as an anti-bacterial and anti-viral agent
- to drive away insects
- to clean carpets and remove ticks
- for laundry washing and ironing
- for mopping floors
- for cleaning cars
What is Garbage Enzyme?
Dr Rosukon's Garbage Enzyme is a complex organic substance of protein
chains and mineral salts and juvenile hormones.
Functions of Garbage Enzyme
- resolve / decompose
- transform / change
- compose / make up / combine
- catalysis
As a result of catalysis, ozone is produced which can reduce the amount of
carbon dioxide in the atmosphere and this in turn reduces global warming.
This enzyme can be produced easily with the organic waste from our
kitchens.
During enzyme production, O3 NO3 CO3 are generated and these could
help purify and whiten the clouds in the sky. Those clouds that trap lots of
heavy metals appear dark. Those dark clouds cause more heat to be
trapped on earth. O3 (ozone) from the Garbage Enzyme could reduce the
heavy metals in the clouds and this would reduce global warming.
More NO3 (nitrite) in the air is useful as nutrients for the plants and soil.
Use Garbage Enzyme to Clean the Environment. This enzyme will
neutralize toxins and other pollutants in rivers, soil, atmosphere, thereby
refreshing our Earth.
Direction for use:
Garbage enzyme can be used diluted with water at a specific dilution ratio.
In homes, garbage enzyme is used:
- to remove foul odours, molds and grime in the kitchen and toilet
- for cleaning cars
DILUTION RATE # USAGE # QUANTITY # APPLICATION
Bath (add in bath water to improves skin condition) # 50~100cc # Keep
overnight
Washing machine (clean and soften laundry) # 20-50cc # Soak and wash
Concentrated # Toilet bowl (prevent blockage & purify sewage) # 250cc #
Pour and flush
Enzyme # Toilet cistern (purify water) # 20-50cc (two caps) # 2-3 times/
weeks
Garden pond & water tank (purify water) # 1/10,000 litre water # Add
occasionally
Leather sofa (clean mold or stain) # Appropriate amount # Spray and
wipe every 10 days
Carpet & tatami mat (deodorize & antiseptic) # Slightly moist # Spray 1-2
times/month
Shoe, inside the car (deodorize & antiseptic) # Appropriate amount #
Spray occasionally
10-50 times # Kitchen sink, stove, cooker hood (clean oily stain)
Appropriate amount # Soak and wipe occasionally#
Black mold (antifungal) # Appropriate amount # Soak and wipe
occasionally
Pet excretion, pet house (deodorize & antiseptic) # Appropriate amount #
Spray occasionally
200-500 times # Air-conditioned room (humidifier, deodorize &
antiseptic) # Appropriate amount # Spray occasionally
Bathroom sink (clean) # Appropriate amount # Soak and wipe
occasionally
Cabinet and refrigerator (deodorize) # Appropriate amount # Spray
occasionally
500 times # Drain (prevent drainpipe blockage) # Appropriate amount
Flush occasionally
Pet (bathing, deodorize & antiseptic) # Appropriate amount # Upon
bathing or brushing
Toilet (clean, deodorize & antiseptic) # Appropriate amount # Spray when
wiping
500 - 1000 times # Indoor (purify air, deodorize & pest control) #
Appropriate amount # Spray frequently
Closet, clothes (deodorize & antiseptic) # Slightly moist # Spray
occasionally
1000 times # Seeding and planting (fertilizer) # Appropriate amount #
Rinse once
Save on household cleaner and body care:
For shampoo, dish wash, laundry liquid etc: use enzyme to reduce
chemical toxicity.
Ratio = 1 part enzyme : 1 part detergent/cleaner : 10 parts water
Washing vegetables: Add 30ml (2 tbsp) enzyme to 1 litre water. Soak for
45 minutes.
Floor cleaning: Add 30ml (2 tbsp) enzyme to moping water. To clean and
sterilize.
Car care: Add 30ml (2 tbsp) enzyme to water tank to reduce car
temperature.
Uses of Garbage Enzyme
FOR GARDENING OR FARMING:
Dilute to 1000 times with water for use as natural insecticides, herbicides,
pesticides and organic fertilizers. Also can be used to stimulate plant
hormone to improve quality of fruits and vegetables and to increase crop
yield.
Spray on idle land for 3 months continuously to improve soil quality.
In agriculture, garbage enzyme is used:
- to reduce the usage of chemical fertilizers
- to keep the farm free from insects and infections
- as a soil fertilizer for vegetable growing
- as a natural pesticide and herbicide
- to convert sandy land to fertile farm land
- keep the air cool and clean in the farm atmosphere
- clean the dirty and impure water in the farm
If every household makes and uses enzymes, it would help tremendously
in the reduction of global pollution.
The 10 Good Points about Garbage Enzyme
1. Clean our air: During catalyst - produce O3, not only can kill bacteria,
but will increase the oxygen in the air. Mix 1:500-1000 enzyme of dilution,
put it in a spray bottle, spray to the air will keep the air clean, eliminate
bad odor!
2. Keep the Toilet Clean: use Garbage enzyme to wash the toilet, can
prevent clogs, destroy harmful bacteria, dirt and clog will break down by
the enzyme. Repels mosquito, cockroach and rats.
3. Keep Our Homes Clean: Add 2 table spoon of garbage enzyme in the
floor cleaning water will clean the floor and kill bacteria.
4. Keep the Kitchen Clean: Use the diluted garbage enzyme to clean
cooker hood, stove top, oven......kitchen ware, can effectively clean out
the most stubborn stain.
5. Keep the Clothes Clean: soak the clothes with small amount of garbage
enzyme, can reduce the detergent, and will make the washing procedure
easy and soften the clothes.
6. Clean Veggie: When washing fruits and vegetables, add a small amount
of garbage enzyme, clears pesticides - safer to eat.
7. Skin Care: Add 1:10 of diluted garbage enzyme to shampoo, shower gel,
dish washer, detergent, can reduce the usage, and neutralize harmful
chemical toxins, prevent skin allergies to our body.
Use garbage enzyme to soak our body will improve skin problem, and
make our skin silky soft! Do not dilute in hot water destroy enzyme
8. Pet Care: Use diluted garbage enzyme to clean your pet, spray their
house, will neutralize pet odor and make your pet grow healthy, even
growing more hair!
9. Vehicle Care: add a small amount of garbage enzyme to your vehicles
water box, will cool down the engine, lengthen the car usage, spray in the
car will neutralize bad odor.
10. Natural Fertilizer: diluted garbage enzyme 500-1000 times, use to
water the plants, flowers, trees.
Makes very good fertilizer and help the plants to grow.
Water the empty land for 3 consecutive months to change the soil to good
quality.
Last tip: If everyone can turn their garbage to enzyme, we will protect our
Ozone, and live in a pollution free environment, food will free from toxin.
Garbage enzyme can use in every household
If every family use garbage enzyme to replace chemical cleaning products,
Then there will be more garbage enzyme flow down to our drainage
system, cleanse our rivers and seas, save our earth.
Turning our garbage to gold is very easy, good for us ALL!
Please start doing it now and at the same time save money on expensive
chemical cleaners!
Help pass the word around.
Remove these ads by
Signing UpStep 1Materials needed
organic kitchen waste - 300 grams waste or 3 Parts
water - 1,000 grams or 1 liter water or 10 Parts
Plastic bottle or Plastic container (depends on what quantity you want to make - 100 grams sugar : 300 grams waste : 1,000 grams or 1 liter water will require a container that can contain 1.5 kilograms in contents).
I think there is a drinkable type, require constant opening of the lid, best check it out elsewhere.
Mine process is non-drinkable.
Pls handle GE with care, it can kill plants if given in huge doses.
Mix 1 part GE to 500 parts water to stimilute plants.
because of i am currently studying about the garbage enzymes..I would like to ask more info about garbage enzymes..1st, I would like to ask about the parameters of the garbage enzymes such as pH, BOD,COD,and etc..is there a standard parameters for the enzymes produced?
2nd,i would like to ask the details of the garbage enzymes?is there specific name for the enzymes produced and is different kind of enzymes will be produced if I use different kind of fruit dregs?
3th, I would like to ask what is the effects of the garbage enzymes to human being and plants surrounding?
last but not least, under what condition,enzymes will die or malfunction?is there any journal or thesis about garbage enzymes that Dr. Rosukon has made so that i can refer to?
thanks..
You can try but make sure thet are half full - but do at our own risk.
Just open one today, I put into a 1.5 litre plastic 100plus bottle - - so much gas fizzed out when I open the cap like open Coke bottle after shaking it.
I think there is an edible version of GE, but much time and trouble.
If you want to waste your time listening to other peoples suggestions, then best not waste your time and money amking GE.
Earlier there was a lady who did this and I hv warned against doing so.
Read the earlier comments.
And in another comment I also told not to use loose fitting lids or caps.
The tighter the the lid the Better.
I do not open the lid until the 3 months are over, at times even 5 months as I hv plenty of this GE.
Try to keep it air-tight.
I'm was thinking to work with the wet market to get some fruit peels to prepare the enzyme. Based on my readings, this enzyme can be used for:
1. Fertilizer
2. Insecticide
3. Pesticide
4. Odor control
5. Hormone for plants and
6. Shampoo, detergents......with certain ratio of water dilution
My question are:
1. How do I prepare the enzyme to suit the said purposes? Is there any different amount of mixture to prepare them? Maybe there is certain types of fruits suitable for fertilizer and some is more suitable for odor control...
2. What / Which source of water is the best to prepare the enzyme? e,g: tap water, river water, fresh water...etc. And why?
Thanks
But any filtered water will do - if you do not have filtered water, just let the tap water sit in a pail for a day and the chlorine will vapourise out as gas.
1. How do I prepare the enzyme to suit the said purposes? - Only ONE type of enzyme is produced.
Is there any different amount of mixture to prepare them? - NO,
the earlier comment by the lady was wrong - DO NOT FOLLOW it.
Maybe there is certain types of fruits suitable for fertilizer and some is more suitable for odor control. - I used the enzyme for all from deodorizing the toilet of foul cigarette-related smells to promoting plant growth by spraying. (Yes, there is a factor in using different fruits as the fruit fragrance will come out with the enzyme. Grapefruit gives a orange fragrance, papaya is worst - smells sh...
2. What / Which source of water is the best to prepare the enzyme? e,g: tap water, river water, fresh water...etc. - Use filtered water - no chlorine if possible, better absorption.
The most important is to use raw sugar or from unprocessed sugar, however even processed white sugar can be used, if you have difficulty in getting the raw stuff.
Anyways here you go an article about ozone i readed http://www.epa.gov/oaqps001/gooduphigh/
You do not drink the GE.
GE when mixed with chemicals in shampoos, dish wash, etc. neutralizes the toxicity of these chemicals.
I use it in my shampoo, dish wash.
Water plants - take care use only small amounts - 1 parts to 500 parts is quite safe..
can I make that in only a week?
pls... help me for my grades
-spongeguile.....
tnzx :)
Helps the environment too.
I was wondering if you could stop using shampoo, soap and detergent completely and use the GE instead?
First: Are you saying that Ozone is good for the environment? Because it captures CO2?
Ozone is toxic, is used as a disinfectant and is currently monitored as a dangerous gas to have at ground level. Ozone is useful to us in the stratosphere.
As far as I know Ozone does not capture carbon from CO2. Again, Ozone is NOT O2 which is breathable Oxigen.
Second: anaerobic decomposition produces methane which is at least 25 times more potent than CO2 as a greenhouse gass.
Third: CO3 and NO3 do not exist as is, should be CO3(2-) and NO3- they are anions, and are always part of a larger molecule like KNO3 (Potasium nitrate). As anions, they never stay as that, they combine with what ever atom will lend them electrons.
So please would you elaborate a little more on the basis of this Idea?
What I do with my organic garbage is managed aerobic composting (managed to avoid methane and faster production).
This sound nice, but I have my concerns.
