Garden Art - Glass Totems
Here is a great little project to use up any glass dishes, lamp shades, or other glass pieces you might have lying around the house. It's a fun way to recycle and create art for your yard and gardens. I have more pictures on my website along with complete instructions. http://www.gardensandcrafts.com/totems.html
You will need assorted glass dishes that have a flat surface area for the glue. I prefer to use cut glass as it hides any condensation you might get if your totems are displayed in the sun. Good examples are plates, salad bowls, saucers, vases, goblets, hurricane lampshades, toothpick holders, desert bowls, etc.
If you don't have any glass dishes to use, you can find them inexpensively at flea markets, garage sales, thrift stores and online. I don't know what is more fun...collecting the pieces, or actually making the totem. I've also gotten them free by waiting until the end of a yard sale or garage sale. There is usually a box of stuff by the road that they don't want to keep. It's amazing what people will throw away.
Colored glass works well to, but is usually more expensive, plus you need to be careful that the glass you are buying is not painted because the paint will peel off when exposed to the elements for a period of time. I don't like to spend more than $2-$5 per piece, and inexpensive colored glass is usually painted.
You will also need an outdoor clear silicone glue to glue the pieces together.
This project was also featured in the Woman's Publication Gardening & Deck Design (April 2009 Issue).
Step 1Collecting your glass pieces
Look for pieces that will stack well together and have a flat gluing surface on the bottoms. This will help prevent water and air from getting inside once they are glued together and it will help the totems look level when you have a flat gluing surface to work with.
Personally, I like to glue a plate between each piece. I think this adds to the overall look as well as helping the pieces be sturdier once glued together.
29 comments
Feb 9, 2012. 11:03 AMwmkcross says:
might be cool to add a solar powered light as a stake. the light would difuse up into the totem at night.
Aug 26, 2011. 7:54 AMrichlgordon says:
If you want to start your totem with a larger more substantial vase or bowl, I don't understand how you can anchor something 4 or 5 feet high to the ground using PVC pipe, even though I love the idea of using PVC (visible or invisible). I also like the idea of putting the PVC over rebar, I just don't understand how a few inches or so of PVC can stabilize and hold something in place.
Jul 23, 2011. 11:50 AMLady Gettysburg says:
Hi I just joined. My friend showed me some pictures of totems she makes and these are by far neater than she hers. I just collected 2 boxes of glassware from a thrift shop and with this great information, can't wait to get started. I will post some of mine after I get them finished.
Jul 8, 2011. 7:16 AMHandy-nan says:
Brilliant!!! idea of using the rebar and conduit, then painting the conduit. I've collected up an assortment of items to build my first totem. I've been trying to figure out the best way to secure it in the garden. This is perfect!!! Thanks!!!
Mar 23, 2011. 10:01 AMfleur2 says:
Specifically, what kind of Lexel do you use? Glue? Caulk? Clear" Thanks. I'm collecting stuff for a totem and want it to last.
Mar 31, 2011. 9:42 AMdianajc says:
I am using an aquarium silcone for my outdoor glass projects. it works great and is not toxic like most of the other silicones.
Mar 9, 2011. 4:09 PMquiltbev says:
I can't find the discussion about the glues to use with the glass totems...I used Well Bond and it is still white after 4 days--not clear! Did I use it too thickly do you suppose? I can't find that Lex--whatever. Any ideas of who might carry that one?
Thanks for the inspiration--lots of fun! I just want my glue to be clear!:-)
Jan 10, 2011. 9:01 AMzowi420 says:
for the bottom piece, just use an upside down vase or glass soda pop bottle. It is perfect to slide onto the copper pipe (or stick or whatever), and the bottom, which is now the top, is a flat surface, perfect for stacking the dishes you've picked for the project: Tip: Less is better!
Mar 29, 2010. 1:44 AMbauble says:
Thanks for the great idea. I've made one too, but haven't glued it. I used 3 plates, 1 drinking glass, 2 candle holders and one funny shaped thing at the top. Actually it's similar to the glass object at the top of the photo in Step 5.
Dec 26, 2010. 8:31 PMquiltbev says:
I think that's a "ring holder" at the top--used for holding the wedding ring while
doing dishes by hand--Obsolete?
May 13, 2010. 1:03 PMsuhuben says:
How are the totems attached to the poles? I've made similar items but always used my  drill press to drill thru plates & bolt them to the pipe. I got some free galvanized poles that I am using, now, but I like the idea of PVC if you could tell me, please how you attach the totems to the pipe.
May 13, 2010. 7:17 PMsuhuben says:
I sure have been doing it the hard way, but don't they slip off the pvc when it's windy or rainy? It doesn't seem sturdy enough to me. I have also used hocky pucks to stabilize the bird baths I have made out of crystal & glass. I drill an opening to insert the pipe (I've been using copper of galvanzied) so the first plate has a sturdy base. Then I screw it into the cap & use putty to hold the cap onto the pipe. It's a lot more involved than it need to be, from what you just told me. I am going to try it! Thanks!
Oct 31, 2010. 5:17 PMenemigo says:
Try a little silicone sealer on the end of the pvc it´ll act like glue and is not hard to remove later
Aug 5, 2010. 2:34 PMsgsidekick says:
I made the mistake of showing this site to my mil, who demanded to know where HER gardenglass thingy was!! I finally broke down and got some pieces from the dollar store and ended up with a very nice "thingy"...which she now is using as a kitchen table centerpiece!! Go figure! Thanks for this 'ible! It is very cool!
Oct 31, 2010. 5:15 PMenemigo says:
try looking in the"goodwill" for old kitchen dishes and candleholders
May 15, 2010. 9:47 AMsuhuben says:
Thank you so much! I am going to try it. But, I must admite I love using my drill press! Your idea is so much simpler, cheaper, & I am excited to try it.
Apr 21, 2009. 2:09 AMartist without a medium says:
Very nice. I may try this using of old glass insulators.I'll let you know how it turns out.
Oct 23, 2009. 6:06 PMmjreneau says:
We have some old glass insulators in our shed; they are so pretty, but guess I'm not creative enough to figure out something neat to do with them.  Did you ever do anything with yours and if so, could you post a photo, so those of us who are creative-challenged can benefit?
Thanks,
MJ
Mar 21, 2010. 2:52 AMbauble says:
This is a beautiful idea GardensAndCrafts. I'll be doing this for sure. Might take apart a solar garden light and put it in one of these glass creations.
As for the glass insulators, I got some big ones when a telegraph pole on my old street was replaced. Here's some pictures of them in my old garden. The insulators would have been 10 or 11 inches across and were very heavy.
Mar 21, 2010. 2:53 AMbauble says:
Here's another lot hanging from a tree.
Jun 18, 2009. 8:55 AMmunsey says:
I used 2 tubes of fish aquarium silicone for three birdbath towers. I am enthused with the prospects of different colors and crockery options.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
19
Author:GardensAndCrafts
