You will need assorted glass dishes that have a flat surface area for the glue. I prefer to use cut glass as it hides any condensation you might get if your totems are displayed in the sun. Good examples are plates, salad bowls, saucers, vases, goblets, hurricane lampshades, toothpick holders, desert bowls, etc.
If you don't have any glass dishes to use, you can find them inexpensively at flea markets, garage sales, thrift stores and online. I don't know what is more fun...collecting the pieces, or actually making the totem. I've also gotten them free by waiting until the end of a yard sale or garage sale. There is usually a box of stuff by the road that they don't want to keep. It's amazing what people will throw away.
Colored glass works well to, but is usually more expensive, plus you need to be careful that the glass you are buying is not painted because the paint will peel off when exposed to the elements for a period of time. I don't like to spend more than $2-$5 per piece, and inexpensive colored glass is usually painted.
You will also need an outdoor clear silicone glue to glue the pieces together.
This project was also featured in the Woman's Publication Gardening & Deck Design (April 2009 Issue).
Step 1: Collecting your glass pieces
Personally, I like to glue a plate between each piece. I think this adds to the overall look as well as helping the pieces be sturdier once glued together.
Step 2: Preparing the glass pieces
Step 3: Gluing
Step 4: Displaying your totems
Rebar is pounded into the ground first and then the conduit is placed over that. The great thing about conduit is that each end is slightly bigger than the remainder of the conduit so you have more flexibility in what you use on the bottom of your totems. I've found the short wide mouth vases that narrow as you get closer to the bottom and toothpick holders work great.
Visit Our Store »
Go Pro Today »
Thanks,
MJ
As for the glass insulators, I got some big ones when a telegraph pole on my old street was replaced. Here's some pictures of them in my old garden. The insulators would have been 10 or 11 inches across and were very heavy.
It looks awesome
I've managed to track down the original photo from 2005. I've taken a screenshot of it at full size, but digital cameras back then weren't what they are now...
So you should be able to see a bit more detail now. It looks like I've used two shackles. I used two instead one just for the extra length. Safety is the most important thing, these shackles are very sturdy as you can see. I've secured the top shackle to the tree using a good sized coach screw. The bottom insulator is secured to the other one with another shackle which also happens to have a split pin through it.
I was thinking about these glass insulators a few days ago and wishing I could get some more as I left those ones in the garden when I moved away.
http://www.gardensandcrafts.com/pvccrafts.html
http://www.gardensandcrafts.com/conversationarea.html
I also have not had luck with solar lights. For one thing the light usually stops working long before my totem breaks or comes unstuck and I don't like how they look during the day when they are not lit.
or, how about finding a a fitting that will fit into the bottom piece and glueing it onto the end of the pvc?
Thanks for the inspiration--lots of fun! I just want my glue to be clear!:-)
doing dishes by hand--Obsolete?
I've had some totems that were a little wobbly so I just wrapped the end of the pipe with a little saran wrap and it was fine. If you use the grey pvc conduit found in the electrical section, it has a thicker end, so you have two choices of the size of glass pieces you can use for the base.
Once painted with paint, you can't even tell it's pvc, especially if you use a hammered copper coloed paint. I like to use the spray paints made for plastic or use a plastic primer and any color regular spray paint.
Good luck....this technique works great for me.
