You will need assorted glass dishes that have a flat surface area for the glue. I prefer to use cut glass as it hides any condensation you might get if your totems are displayed in the sun. Good examples are plates, salad bowls, saucers, vases, goblets, hurricane lampshades, toothpick holders, desert bowls, etc.
If you don't have any glass dishes to use, you can find them inexpensively at flea markets, garage sales, thrift stores and online. I don't know what is more fun...collecting the pieces, or actually making the totem. I've also gotten them free by waiting until the end of a yard sale or garage sale. There is usually a box of stuff by the road that they don't want to keep. It's amazing what people will throw away.
Colored glass works well to, but is usually more expensive, plus you need to be careful that the glass you are buying is not painted because the paint will peel off when exposed to the elements for a period of time. I don't like to spend more than $2-$5 per piece, and inexpensive colored glass is usually painted.
You will also need an outdoor clear silicone glue to glue the pieces together.
This project was also featured in the Woman's Publication Gardening & Deck Design (April 2009 Issue).
Remove these ads by
Signing UpStep 1Collecting your glass pieces
Personally, I like to glue a plate between each piece. I think this adds to the overall look as well as helping the pieces be sturdier once glued together.
or, how about finding a a fitting that will fit into the bottom piece and glueing it onto the end of the pvc?
Thanks for the inspiration--lots of fun! I just want my glue to be clear!:-)
doing dishes by hand--Obsolete?
I've had some totems that were a little wobbly so I just wrapped the end of the pipe with a little saran wrap and it was fine. If you use the grey pvc conduit found in the electrical section, it has a thicker end, so you have two choices of the size of glass pieces you can use for the base.
Once painted with paint, you can't even tell it's pvc, especially if you use a hammered copper coloed paint. I like to use the spray paints made for plastic or use a plastic primer and any color regular spray paint.
Good luck....this technique works great for me.
Thanks,
MJ
As for the glass insulators, I got some big ones when a telegraph pole on my old street was replaced. Here's some pictures of them in my old garden. The insulators would have been 10 or 11 inches across and were very heavy.
http://www.gardensandcrafts.com/pvccrafts.html
http://www.gardensandcrafts.com/conversationarea.html
