3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Garden Hose Repair
Garden Hose Repair
I know that garden hoses are not that expensive but I can't bring myself to go out and buy a new one when I can fix the one I have. Either end or middle of a garden hose can be replace. This instructable will go through how to replace the end of a garden hose.
You will need:
Broken garden hose 5/8"
Replacement end (male in this case 5/8")
Hose clamp
Utility knife (or some other thing that will cut the hose)
Screwdriver
Step 1Examine Hose and cut
When you find that your garden hose has gone bad, check to see if where you found the problem is the only place. In my case, there were there place near the end, the rest of the hose was still good. If there are several bad places along the entire length of the hose, then maybe it is time to go get a new hose.
After the third place at the end were the hose is going bad is where I am going to make my cut. I cut the hose a couple inches back from the last bad spot to insure is will be working with good hose.
18 comments
Apr 22, 2010. 1:51 PMdevynhogan says:
if you cant get the new end peice on put the hose into hot water for a minute of two then it goes fight on :)
Apr 12, 2010. 8:17 AMstephenniall says:
My way is very similar but i dont use Brass connectors.
I put one piece of pipe on the Gas hob (or lighter) and i melt the end a bit and it Expands therefore so You slot it over the other pipe and put a hose clamp on it
Apr 12, 2010. 6:20 AMfrankboase says:
What about using a bicycle inner tube,l cut them up to form bandages wrap one around the hose a few times,tuck the end in and bob's your uncle.
Apr 12, 2010. 2:08 AMstatic says:
Personally I prefer hose end or splice fittings that don't require this sort of hose clamp. A clamp that is always getting hooked on something when you drag the hose around. Most hose repairs that aren't jury rigged should be a strong as the hose, so I really don't know why one commentor had problems with the  repair ends blowing out. I'm rural so I leave my water hose out all year long in case of fire. Call 911 first, and to what I can to mitigate the situation until the FD gets here. A new hose every few years isn't going to break me, but just may save me money. Fortunately I have never had to put the plan to a test.
Apr 11, 2010. 4:03 PMshushujooon says:
That's cool... we just keep cutting our hose... never knew you could replace the tips.
What about leaks?  is this method leak proof?  can i attach garden tools to the end and not have water squirted back at me?
Apr 11, 2010. 8:37 AMbabylonfive says:
This works great for damage-related failures near the end of the hose, but for a really old hose (assuming you don't have the Sears guarantee solution), you might end up sharing my experience... fixes to a very old sun-damaged hose simply exposed more failures and damage,... more and more hose is lost reaching the next supposed solid portion before the pressure reveals another weak spot.
Such hoses, unfortunately, are lost. Think about this before buying your second hose clamp, male or female replacement end, etc.
Apr 11, 2010. 10:51 AMseanrdz says:
 you could just use a small (1" - 2") piece of 15mm copper pipe and two jubilee clips and only waste the bit of hose where the kink is.
Apr 11, 2010. 8:18 AMthe rural independent says:
Use it up.
Wear it out.
Make it do or,
Do without.
From a friend whose Irish mother pounded this into her kid's brains.  All of them became very frugal and very wealthy adults.
www.theruralindependent.com/
Jul 1, 2007. 1:01 AMdchall8 says:
The last hose I bought was in about 1985. It was then that I discovered the lifetime-guaranteed hoses at Sears. When my dog bites a hole in it, or I drive over it on my stone driveway, or whatever (which seems to be about once every other year), I return it and get a new one - no questions asked.
May 28, 2009. 6:42 AMtrgz says:
Lifetime guarantee?! Damn I wish I could find that in the UK - my dog seems to think that my garden hoses were 'stick-on-a-roll' and delights in biting out sections whenever I forget to put it away. :-(
Apr 23, 2009. 2:00 PMPlayPatterns says:
this reminds me of when i was a truck driver and used to take tie down ropes and tie them together over and over again until i just had a chain of square knots. before you know it you'll have a brass hose!
Jun 30, 2007. 10:35 PMM_Tocci says:
We do that at work all the time. Just dont let pressure build up or it might blow the replacement end out... it has happened afew times tome.
Jun 30, 2007. 7:21 PMlemonie says:
You're like my dad. If he cuts through the cable of his hedge-trimmers he'll go and get a terminal block and do a splice like this. I don't really understand what "gone bad" means - is this just mechanical fatigue, exposure to sun, or something else?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:AT
