Garden Markers
Introduction: Garden Markers
This is a fun and crafty way to mark what is planted in your gardens. Veggies or flowers it matters not. Markers can be moved each planting as you rotate your crops. A good way to re-purpose old or broken tiles and pavers. I also used rocks. Any size and shape with at least one flat or semi-flat surface will work just fine.
Step 1: You Should Gather Up What You Need Before You Start....
1st you should protect the area you will be working in. I did this by working outside on a cardboard box.
Items you should have handy(pic1):
paper cup
paint brushes
paper towels or rags
paper plates
Paints (Not water base or poster paints) at least 2 or 3 colors More is better!
Items you will paint: rocks, tile pieces etc.
Extras you may choose to use(pic2):
sand paper
paint pens
Nail polish
Sharpie markers
Collect all your goodies and set them out on your protected work area!
Fill your cup with water, for your brushes.
Then put your paints on or near your paper plates
Set out your paint brushes (make sure to check your brushes for loose hair, and remove them)
One last prep, Wash the items you plan to paint. scrub off any old dirt, oils, cobweb and other icky stuff.
Now you are ready!
Step 2: Time to Paint
Squeeze or pour a small amount of paint onto the paper plate. Do the same with 2 or more colors. Choose a color as the main back ground for your first marker and paint it on. You can paint only the top surface, and top and sides. Whatever you like best. Allow to dry.
Step 3: Just Have Fun With It.
Mix it up. Have fun, blend paints, anything you like. Just keep in mind that you will want it to stand out in the garden and be easy to see and read. You can make them all alike or each one unique like I did. I used neon colored nail polish on some because I liked the bright colors and I did not have any paints in neon and did not want to go to the store. I also used glitter on some while the paint was still wet. Allow to dry.
Step 4: The Creative Part
After they have completely dried, you can add more details. However you choose. Using more paint you can add anything you want. Stripes, stars, flowers, a sun. Actually anything you can paint. Just remember to only use waterproof materials. Now we take a break while they dry again!
Step 5: Final Step
With your paint pens or Sharpie pens add the name. Some of mine I added a phrase or one liner to.
Or something like, "Corn grows here", "Meet my Beets", or "Mellow Melons"
Now everybody will know exactly what is growing and where.
Remember to use White or light lettering on dark backgrounds, and Black or dark letters on light backgrounds for easy reading. Once they have dried you can go place them in your gardens!
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    Excellent idea! I usually just have an issue telling them apart when they are just seedlings.
    I have that trouble also. At the start of each season just remembering exactly where I planted what is really tough. Sometimes I use two markers at each end of a row. At least until they break the surface.
    And thank you for commenting on my very first published Instructable
