Garden Seating, Incorporating Retaining Wall
Introduction: Garden Seating, Incorporating Retaining Wall
Having now got my shed just about completed It was high time that I started on relaxing areas of the garden, So I have decided to build some modular style seating and a "chill" area.
It's not exactly Chippendale, but hey it is garden seating!
Step 1: Dig Out the Area
Obviously nothing is easy! Step one is to dig out an area to put the seating.
Due to access limitations this was all done by hand and barrow, (well it keeps me fit!) and was done over a weekend, the fill was put into my raised 6m x 3m bed as subsoil for root vegetables (potatoes, kumara etc)
Approx 12 cubic meters of soil was removed, the first photo was taken a few hours after starting and the second at the end of the weekend from approx the same angle (There is a rose at the base of the white sack and you can see how much was removed by its position on the second pic (I have put a box around on the pictures))
The pic of the raised bed is after Day 1 (approx 75 barrow loads of soil)
While I had the spade out I also planted a trio of citrus trees (Lemon, Lime and Satsuma), which were previously in pots inside the pool area, the red frames are to stop the dogs/chooks etc digging them up.
Step 2: Digging Complete (I Hope!)
From the reverse angle you can see I have dug the area in a "lazy S" , however the storage bench will be laid out in an approximate semi circle. The bench already there will be relocated (and I may even do an I'ble on building one of them later)
Step 3: Costings
I had quite a bit of the timber lying around from previous projects but will cost as closely as I can, all prices are in NZ$. However if you are on a budget, there is no reason why this entire project couldn't be made from pallets, including seat bases. In that case all you would need to buy are the fixings.
Exchange rates NZ-US 0.68, NZ-GBP 0.44, NZ-Euro 0.60
4 x 2 for frames 3.5m per frame 7 frames $3/m --------------------------------$73
4 inch nails 3kg -------------------------------------------------------------------------$25
2 inch screws (1/2 box) ---------------------------------------------------------------$13
18mm decking 70m --------------------------------------------------------------------$153
1 sheet 18mm ply -----------------------------------------------------------------------$54
3 sheets 12mm ply ---------------------------------------------------------------------$100
35mm screws (found in bargain box at Bunnings) $5 a box ---------------- $10
Black builders plastic free from skip ------------------------------------------------$0
Varnish/stain ------------------------------------------------------------------------------$40
Seat Squabs 6 @ $59 ea -------------------------------------------------------------$354
TOTAL $822 (US$560,362 GBP,493 Euros)
Step 4: Frame Cutting List
I have 4 cushions, thus I need 5 frames (I will probably buy a couple more cushions and extend this bench, but the rule is 1 more frame than cushions!)
Each frame is made from 4x2 (or 2x4s if you're an American!)
To give me the heights I want, and to fit the cushions they are cut as follows
1x 1200mm
1x 650mm
1x 570mm
1x 520mm (not 500 as written on it in the picture)
All these were straight cuts on the chop saw
1x 530mm
This had 15degree cuts at both ends as shown to give a sloping back rest
Step 5: Tools
Because I have a lot of powertools that is what I mainly used, HOWEVER all of this could be done with handtools provided you meet the following criterion:-
1. You are mad
2. You are very poor!
So I used (in no particular order)
A Chop Saw
A Table Saw
A Circular Saw
A Jigsaw
An Oscillating Saw
A Drill Driver
A Hammer
A Belt Sander
A Detail Sander
A Spirit Level
A Tape Measure (optional!)
A Pen or Pencil (or crayon if I can get it out of my nostril)
Brute Force
A Lot of Beer!
Step 6: Assemble
Assembled with 100mm nails with the exception of the top of the backrest which I screwed with 2.5 inch screws.
I allowed 200mm at the base for the legs to be buried to give stability
Once I had made, and was happy, with the first one I used it as a template and assembled the rest on top.
Step 7: Siting (First Fit)
I put the frames in position and buried the legs making sure they were upright, the seat was flat and, most importantly, that they looked right.
I used one of the cushions as a spacer/template to ensure correct positioning of the frames
Originally I was going to bend the decking to fit, but this proved troublesome so I cut lengths and screwed them into position along the front and top of the backrest.
At this point the frames are only temporarily sited as I need to remove them to panel out, however will make them more rigid first. I also need to make sure the base is flat (so maybe a little more digging ;-) )
The backrest and front are to be boarded with 18mm decking timber
This was when I decided that I actually needed to make it larger with 6 seats instead of 4 as it would look better
Step 8: So I Built 2 More!
I cut some 18mm ply (marine ply) for the seat bases and screwed this into place to brace everything in the correct positions.
Now at this point I started putting all the seat faces on (18mm decking timber) Then suddenly realised that I wouldn't have enough space attach the backs to act as a retaining wall, and screw the storage box bases on (unless I dug a s***load more earth out).
Soooooooooooo I dismantled it all and reassembled in 3 pieces, with the backs on, then lifted/slid it all back into place and.
The backs are 12mm marine ply and I will staple some plastic sheeting onto it to act as a moisture barrier between it and the bank before I backfill.
I did take some pics but the camera said no! I have no idea where they disappeared to - will have to try the internal drive (found out I had camera on panorama and didn't save - what a klutz)
Needless to say it is very heavy and hopefully not coming out again!!
I then started replacing the Decking timber,
Step 9: The Seat Bases and Backs On
So this shows the seat base in position, all are slightly different I basically cut a piece of 18mm ply sheet to fit - measuring stuff is for losers!
The two seats nearest the camera have the bottom base on the underneath of the bottom stringer rail - this gives an extra 2 inches (5cm) of space which I need for a couple of the things I am going to store. The other 4 will have the base at the top of the stringer as it is easier to attach and if I had panelled it all out it would have been too unwieldy to move.
As you can see there is still some earth to move (and bench to relocate)
I would like to take this opportunity to thank the chooks for all their assistance!
Step 10: And Backfill
So I stapled some black builders plastic to the rear of the unit and backfilled (thought I said I was done with this digging lark!)
Step 11: Carry on Panelling
I bought some rectangular, white boat squabs and because of the curve decided to infill with some armrests/drink rests
These were cut to fit out of some 8x2 I had lying around (which was free) plus I screwed some cut down decking to the sides for decorative effect
Because I had only roughly measured/guesstimated the positions of the frames these are all slightly different sizes, however they look ok and their main purpose is to position and secure the cushion/squabs
Step 12: Relocate Bench
Dug it out and transported to other side of garden
Had forgotten how heavy it was!
Step 13: Access to Storage Spaces
I marked out and cut out a rectangular access into the underseat storage spaces, rounded the corners and screwed in ply supports for seat base.
Finger hole drilled in the centre to aid removal
I used an oscillating saw to start the cut, and completed with a jig saw.
Step 14: And Finally.............
Just need to give it a quick sand and stain/varnish it.
I am looking to finish it with a clear varnish for 2 reasons
1. I think it will contrast well with the darker background and foreground when I complete
2. Someone gave me a load of clear varnish free!!!
Next project is a firepit to go in front and some paving/planting
Oh and yes, there was more digging to do before I finished after all!!
    • Paper Contest 2018
      Paper Contest 2018
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    +1 on this project! Congrats!!!
    This looks great.
    Hope you can use it a lot.
    I Really Want to make a bench thing like this but around my Firepit at my Campsite I think it would be really cool cause then I would always have a place for my friends and family to sit when they come over to sit by the fire or roast marshmallows or what not
    Cute chickens; trying to help. Adorable.
    Yeah--REALLY helpful!!
    Thanks, not exactly fine carpentry but I like using power tools!!
    I like how the comment date says a day ago because we are the opposite sides of the date line!
    And Morning!
