Introduction: Garden Rabbit Deterrent (wind Chimes)
This is in honor of my father and father-in-law who were the ultimate scroungers and urban gardeners. They taught me well.
To begin, all of the stuff needed for this instructable was scrounged or laying around taking up space.
Step 1:
Tools and materials are
Two 2 foot pieces of half inch conduit.
Two foot piece of 2x2 or 2x4 board
Three computer hard drive platters
Nylon fishing string
Primer and spray paint
Three small nails
Drill, 3/4 inch wood bore bit
Angle grinder
Three small nails
Angle grinder
Step 2:
Start with the wood and bore a hole through on each side approximately 1.5 inches from the end. The 1/2 inch conduit will fit perfectly into a 3/4 inch hole.
Step 3:
After boring holes, turn the board 90 degrees and pound in the three nails. Measure the diameter of the hard drive platters and subtract about 1/2 inch to distance the nails apart. For example my platters were 3.75 inches minus .5 inches makes the nails 3.25 inches apart.
Step 4:
Using the angle grinder, cut one side of the conduit at about 30 degrees making a pointed end. This will help for driving into the ground.
Step 5:
Using duct tape, I taped materials to clothesline pole to prepare for paint and primer. Once priming and painting is done you are ready for assembly.
Step 6:
Drive the conduit into the ground and slide on board. Cut enough string to hang the platters at about 6 inches below the board, any more than this, the platters will wrap around each other and twist the strings together in the wind.
Step 7:
That's it then. Enjoy. The "Father's" theory was that animals (like rabbits) avoid noises and movement during the nights when they are seeking food. The platters chime and the reflections create movement. When working in the garden, they often catch my eye with the movement. Seems to do the trick. Makes a nice wind chime also.
