I thought it would be great to combine both these projects and build myself an indoor garden that I could monitor from work via Twitter. Thus began an adventure in gardening and electronics that taught me a lot and took me much longer than perhaps it should have. Fortunately for you I'm going to write down all the steps so you can get started right away. Maybe you'll follow up with this project and upgrade your garden or use this as a guide to start on a similar project. Either way, I hope you'll let me know what you get up to.
If you're ready then head to the next step and begin the process!
Edit: Please see the code now posted on GitHub - https://github.com/chrisgilmerproj/garduino-upgrade
Remove these ads by
Signing UpStep 1Gather your materials
Various Parts Lists:I highly recommend you buy a couple extra parts here and there. You'll find, as I did, that they come in handy when you make a mistake. For the majority of the parts nothing is particularly expensive so buying a few extra things won't hurt.
I would like to figure out a way to take the output (light/sound) and wire in a relay to control say 120VAC to ring a louder bell or flash more lights or set off an X-10 code (their remote sensors don't work at the range the HFT unit does).
I belong to a Google Group on Woodworking that's pretty good but have not found a similar discussion group where one might post such queries and get something other than SPAM and offers of free sex.
If you can help . . .
Thanks
A much easier and potentially safer route is to wire an AC or X10 remote control or other remote control. There are a lot of tutorials for using a micro to control a remote control (the book Practical Arduino has one example, but search the web). Basically you would use a pin from the arduino to electrically simulate a button push (bridge the switch) on the remote. This is a very good beginner-intermediate project.
You might want to check your cars first aid kit as they usually come one with one, just hope you don't need it =)
i will grant that it probably isn't the most accurate thing in the whole world...
I will probably go to something like this mastech unit later. But I'm going to be out of the loop for about a year, so it will be some time before I can start playing around with stuff again :-(
http://www.amazon.com/Mastech-Digital-Illuminance-Light-LX1330B/dp/B000S19W3W/ref=sr_1_1?ie=UTF8&qid=1316452054&sr=8-1
Keep up the good work ;)
If you're attempting to control atmospheric conditions such as humidity and temperature, getting foam-core insulation panels and taping some mylar/panda film to the inside and then making a box of them around your grow area is fairly effective, but a fan to vent excess humidity / temperature is a must in a mostly or fully enclosed area (unless you have other ways of controlling those) - keeping the water reservoir outside the grow chamber helps prevent excess humidity from building up.
A fan is good in any case because it will keep fresh gasses circulating amongst your leaves and even out humidity and such to prevent mold, as well as keeping your plant stems in motion and strengthening them. When my friend was experimenting building his own LED grow lights, we just used some computer fans since the power supply was compatible, they actually ended up helping to make up the difference between the power consumption of the LEDs and the power output of the supply (because all our electronics were hand tooled without any fancy microcontrollers like you kids have today).
This is an awesome project, and I'm totally bummed I can't afford to build something like this to take care of my bonsai - though I'd need soil moisture sensors and the ability to water on a per-plant basis ... or have to re-pot all of the little trees in such a way as they'd dry out at the same speed.
use Mylar its really reflective and you can buy a forum of it at the 99 cent store
tho its extremely thin and can be hard to work with if you get the kind from the
hydro store it's like 25 bucks for 20 feet and alot thicker but yeah i can see why you used the foil and now the lights..
lights, the cheapest !! lights you can get i recommend the light fixture at wal mart for like 12 bucks t12 48in bulbs i would get the cool white with the blue labeling for the vegetative growth in a leafy green plant 6100k to 6500k
should make your herbs grow nice if you have t5 lights those are nice but more expensive thay have them at homedepot for 35
but you could take it so much further and have automated controls from everything to light, heating, ventilation, watering. some stepper motors and your lights on a track and you could simulate the movement of the sun, aeration in hydro settups, why have your pumps going full blast when the lights are off?
i mean this just all off the cuff but the ideas are endless!
I'm new to Adruino and just wanted to understand.
http://svn.chrisgilmer.net/viewvc.cgi/project/completed/garduino/arduino/garduino/garduino_pde/garduino_pde.pde?revision=22&view=markup
I'm glad to see that everything worked out OK for you. Keep making robots!
PS: First!
I hope you got the watertight box for your system worked out, it can be pretty dangerous when it rains if the whole thing is outside. Did you consider changing your relays to GFCI outlets?
Thanks for the encouragement and I hope to hear more about your project! And go FIRST!
