Garlic Amino Salt
Published
Introduction: Garlic Amino Salt
Taking a cue from Chalt, I decided that I should like to make an amino heavy salt. I have previously been led to believe that the flavor advantage of sea salt, particularly highly regarded sea salts such as sel gris, fleur de sel and varied other examples, is the mineral and amino content imparted by the brine from which it is collected. My intention in this case was to create a reduced salt with far-increased amino content, intended to be used in a similar way to soy sauce, but without the addition of liquid. I'm calling this salt "Garlic Amino Salt", as its ingredients are sea salt, alderwood smoked salt, black garlic powder and minced preserved garlic.
Step 1: Initial Addition
As this is a small-batch experimental recipe, I started by adding 250 mL of Spring Water to a medium saucepan over high heat. Once the water started boiling, I reduced the temperature to medium, and added 50g of an ordinary, mid-price Sea Salt.
Step 2: Super-Saturation
I then began attempting to super-saturate the solution with sea salt. After adding 25g more salt, I discovered that the solution was too thick, and added 100mL more water. The solution at that point seemed too thin. I then added 3g of smoked salt and 5g of sea salt, and started adding water in 15mL increments. After 5 such increments, I decided that the solution was appropriately dilute as to be supersaturated at boiling. I then added the black garlic and minced garlic, boiled for 2 minutes more, and poured the mixture through a plastic filter I purchased online into a 2.2qt Pyrex baking dish. It was then placed in an oven at 275F, as shown.
Step 3: Precipitation/Drying
I checked the solution at 15 minute intervals, observing the drying taking place from the outer rim of the dish inward, as illustrated in the following sequence. Note that significant precipitation happened in the first 15 minutes of the process.
Step 4: Final Drying
After 90 minutes of such, I found that the solution had dried into a loose cake. I removed the dish from the oven and stirred it using a silicon spatula. The resulting aggregate was semi-moist, with pockets of completely dry salt interspersed. I decided that the mixture could use more drying and placed it back in the oven for another 30 minutes.
Step 5: Completion, Tasting
At this time, I removed the salt from the oven and stirred it up once again. It had become dry throughout, excepting a few small, moist clusters that nonetheless crumbled between my fingers. Tasting the new salt, it was intensely savory, with a significant but far-reduced saltiness from the original sea salt. I think it would work well as a salt replacement at anywhere from 1:1 to 1:2.5, for any recipe that the cook wanted to make more savory and wouldn't mind including black garlic flavor.
Step 6: Final Thoughts
I believe this recipe would be helped by the inclusion of a vacuum hood for the reduction of the salt, coupled with a significant reduction in drying temperature. When using a vacuum hood, however, I would double the black garlic content and remove all minced garlic. The inclusion of some (5g on the light side to 15g on the heavy side) dried roasted garlic would be preferable to minced garlic in this case.
This experiment had an unexpected but not altogether unwelcome side effect. On a first attempt, I accidentally added the garlic and black garlic early, and decided I should start over. Not wanting to waste perfectly good black garlic, I put the failed recipe in a Pyrex loaf dish in the oven, without filtering, and the garlic mixture reduced down to a thick paste. I intend to put it in a yet undetermined amount of olive or canola oil, and use the result as a cooking paste or condiment.
This instructable is based on a post made on my blog, which includes the experimental data I recorded during production of the salt.
    • Stick It! Contest
      Stick It! Contest
    • Pets Challenge
      Pets Challenge
