I hate to throw it away, so what else can I do with this oily sauce? A long time ago oil used be pretty valuable. It can be eaten, burned, used to lubricate stuff, even make soap. I briefly considered lubricating my bike with it, but decided against it. I wonder if I could make some garlic sauce soap and surprise my wife.
Anyway, this can probably be done with other condiment packets as long as they are mostly oil. Oh, and you should probably know how to put out a grease fire before you start, and don't leave it unattended.
What you need: garlic sauce tub, one sheet of toilet paper, pen, lighter, plate, and lid.
Remove these ads by
Signing UpStep 1Put it together
The packet says shake before use, but it's best not to shake it, or maybe not. I don't know. This is playing with fire not rocket science.
Place the sauce tub on a ceramic plate (do not use a paper or plastic plate). Keep a sauce pan lid close by in case the whole mess catches on fire. Covering it with a lid should put out the fire if things get crazy.
Use a pen and poke a hole in the center of the lid, and feed the wick into the hole. Work the wick around a little bit so you can see it wicking up the oil.
What does it smell like, and does it keep vampires away?
Have you noticed if the lid dimples down because of a vacuum effect?
