Garmin eTrex H Dissassembly
 by zzpza
I wanted to change the backlight LEDs from amber to blue, red or white. Red would be good so as not to mess up your night vision. But I didn't have any LEDs that would work at the drive voltage being supplied. :( By this point I had documented how to take the device apart, so I thought I might as well put it up here.
If you are planning on changing the backlight, you will need two 3mm round (or flat / smd) LEDs that will shine brightly at 1.95V.
Taking the etrex apart and putting it back together again was surprisingly easy, but a little painstaking. Looking at mine now, you can't tell it's been apart.
Step 1: Dissassembly - part 1
Take off the battery cover and batteries. Remove the rubber surround by pulling. It's stuck on with glue. Start at the top where the serial connector is. Don't pull too hard, it's one piece. Place it to one side to make sure you don't get anything stuck on the glue, you can reattach it as it is when you are finished.
dvman says: May 1, 2013. 11:06 PM
Hi , Do you know the the model No. of LED backlight is ?
codeblue12 says: Jun 20, 2009. 7:54 AM
how did you glue the rubber seal back on?
lilpepsikraker in reply to codeblue12Jul 27, 2009. 7:09 PM
Reassembly is very easy. Reconnect the serial cable, snap the two halfs back together, then put the two layers of tape on, then the rubber seal.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
