Feel free to leave any questions or comments.
Remove these ads by
Signing UpStep 1: Parts
Relevant Parts:
Methane CNG Sensor $5
330 Ohm Resistor $0.25 (2)
XBee Series 2 - Wire Antenna $26 (2)
Lilypad Arduino 328 Main Board $22
Lilypad XBee $15
Lilypad LED PCB Set $5
Lilypad Simple Power $5
FTDI Basic 3.3V (for programming the Lilypad) $15
110mAh LiPo $7
850mAh LiPo $9
XBee Explorer $25
XBee Breakout Board $3
XBee Headers for Breakout Board $1 (2)
JST 2-pin Through-Hole Connector $1
SPDT Mini Power Switch $1.50
Other:
Red LED (10)
Green LED
LiPo Charger Basic $10
Mini-B USB Cable
A Black Soft Cotton Hat
Altoids Smalls mint tin
PC
Soldering Iron
Dremel
Needle
Conductive Thread $3
Long Wooden Stick or Umbrella
Hot Glue Gun
Chalk
Visit Our Store »
Go Pro Today »
A bit expensive but I imagine a wired version would be half as much (or less).
I used to work in a gas plant and the H2S detectors also work and level is more proportional to the stink since it is not the methane component that actually smells bad. It was kind of funny when someone wearing a personal H2S monitor would set it off in the lunch room.
Just because it *can* be built, doesn't mean it *should* be built.
//thank you for your attention
Also glad I don't work in a closed space with him.
I find it so intriguing that at your age, you have been able to conceptualize so many of your ideas. Good for you, man.
I do have two questions for you. What inspired you to get into electronics and microcontrollers at your age? Second, I have a younger sister who I am trying to teach electronics fundamentals to. What has helped you learn? What methods were most effective for you?
Again, great job.
*following*
I wanted to get into electronics because I was bored with video games and TV. One day, my dad had found MAKE magazine, we bought a soldering kit, and I made more and more electronics from then on. The way I learned is I got: MAKE magazine, a small soldering kit, a soldering iron, Getting Started with Arduino (book), an Arduino, plus many other components. I made the ArduSensor Fun Pack (also one of my Instructables, for sale at my website, www.qtechknow.com) for beginners to start electronics! They are plug-in-play sensors for Arduino. I recommend that you get an ArduSensor Fun Pack for your sister to get started with electronics, plus all of the stuff mentioned above (if you don't already have it!).
Can you explain the AT commands for the XBee? Like, what does the ATJN 1 command do? Better yet, where do you find Digi's AT command list?
this instructable is brilliant!
...so you can indicate "who dealt it".
