Parts list:
Controller - $300
Motor - From old golfcart ($600 in store)
Wire - $20
Misc nuts/bolts - Already had them ($30 in store)
Contactor - $25
Diode and Resistor - $10
Sprocket - $35
Aluminum Plate and Bar - Already had in my garage.
Misc stuff that I had - $10-50
Remove these ads by
Signing UpStep 1Motor
Type: Series Wound DC Motor
Max Current: 300A
Cont. Current: 100A
Voltage: 36
Max HP: 15
Cont. HP: 5
Length: 14"
Diameter: 7"
Weight: 30Lbs
It was pretty rusted up and the pulley that was on it was a pain to remove. I took the motor apart and cleaned the dirt out of the coils, brushes and also greased the bearings.
now in a electric mode did you field a power loose
against the old gas powered mode?
I think you could use to sopport the electric engina a scisors bolt floor jack whit rubered soports
¡ congratulations ¡
did you make it yet mine go faster 80mph and i put music in mine and add me as a friend1
It is a very interesting project.
And to power the motor you would need a massive bank of panels, for comparison a typical solar system that goes on a house is 5KW, this gocart needs up to 20KW or 4 times the power of a normal house.
