Remove these ads by
Signing UpStep 1What You Need.
2- 3" PVC pipe 15" long
3- 3" PVC Clean outs with caps
1- 1/2 12" long plastic threaded pipe
1- 3" PVC pipe cap
1- 3" PVC pipe coupler
1- 2" PVC 90 degree
1- 14" piece of 1/4" copper tubing
1- primer bulb
1- on / off / on momentary switch or off / on momentary if you use a piezo igniter.
1- coil , condenser , relay or piezo igniter.
1- 12 volt portable air compressor
1- can PVC glue
1- roll solder
1- small tank for gas 1/2 to 2 oz
1- small one way valve
1- pressure gauge minimum 50 PSI (air pump may include gauge and air T ) .
1- air T
1- 4 feet tubing 3/8 OD 1/4 ID for air
1- 4 foot small gas tubing that will fit in the big tubing , the smaller the better.
1- 4 foot spark plug wire
1 7.2 to 12 volt stick pack battery, available at hobby shops.
http://www.rutlandinc.com/industrial/RPT.PVC.Chemical.Compatibility.Chart.pdf
Sort it out covey, go check the spudfiles forums.
