For more details have a look at the project Website.
alan-parekh.com/projects/gear-clock
The Gear Clock Kit is now available. Have a look at our kit page for more details. If you have a CNC machine you can cut your own gears and just purchase the electronics for the clock.
Remove these ads by
Signing UpStep 1Cut and paint the Gears
The gears are made out of MDF. They were painted to have a metallic look however the look I was going for was not achieved. Initially I was thinking of making the gears look like they were made of metal and left to rust for a few dozen years. I found some cool products that would give me that rusted effect but they were a bit too expensive. I settled for a can of Krylon Black Metallic Hammered Finish paint. The sample on the lid is a very nice black with subtle bit of gray. I think this might be from a bad batch since the final look is not as black as it should be. It also made taking pictures of the final clock a bit tough since even with modest lighting the glare was horrible.
The gear arrangement is as follows:
- 9 tooth motor gear
- 72 tooth minute gear with a 24 tooth secondary
- 72 tooth intermediate gear with a 18 tooth secondary
- 72 tooth hour gear
To achieve the correct timing the 9 tooth motor gear is advanced 4 steps every 9 seconds. By moving 4 steps at a time the motor routines can be simple since the motor is always at rest with the same coil energized.
here are the files
You can get the CAD here if you want.
http://alan-parekh.com/projects/gear-clock/
Try RECOVER or DXFIN and see if that can drag it through.
Suggestion to abbtech, try using DWG trueconvert to get a decent file.
I like this project. Thanks.
Ill give it a try on the schools computer.
Weird.
Invalid or incomplete DXF input -- drawing discarded
I should have been clearer with my question.
I would love to to the same with a CNC but I lack experience.
What kind of CAD did you use to generate the gears?
And how did you process them to the CNC?
Thanks.
http://alan-parekh.com/kits/gear-clock-kit/
Going there right now...
Very nice project! In terms of getting a rusted metallic look on wood, I've had good luck spraying the parts with flat black, then just lightly dusting with bronze metallic paint.
http://alan-parekh.com/mailing-list/
Or just keep your eye on this page.
Check out what happens to MDF when it gets wet!
http://forum.hackedgadgets.com/viewtopic.php?t=2589
Looks a bit like the twin cams on a DOHC straight six.
Really interested me mainly because I've had the idea of a planetary clock but given very limited budget and supplies i'd be limited to cardboard and an exacto knife. MDF seems slightly better though... What programs did you use to make the gears? The closest i had was inkscape that has a star tool that can create a gear looking shape that could function but i think its mainly for looks and not functionality. I like the use of the floppy drive motor too.
I used Artcam to design most of it. MDF is cheap and tough, I would use it over cardboard.
