3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Gear Clock
Gear Clock
The heart of the clock is a PIC 16f628A microcontroller (PDF). This microcontroller has an internal oscillator however an external 20MHz crystal oscillator is being used since it will have to accurately keep track of time for weeks and months. The microcontroller is interfaced to two buttons and one motor.
For more details have a look at the project Website.
alan-parekh.com/projects/gear-clock
The Gear Clock Kit is now available. Have a look at our kit page for more details. If you have a CNC machine you can cut your own gears and just purchase the electronics for the clock.
Step 1Cut and paint the Gears
The gears are made out of MDF. They were painted to have a metallic look however the look I was going for was not achieved. Initially I was thinking of making the gears look like they were made of metal and left to rust for a few dozen years. I found some cool products that would give me that rusted effect but they were a bit too expensive. I settled for a can of Krylon Black Metallic Hammered Finish paint. The sample on the lid is a very nice black with subtle bit of gray. I think this might be from a bad batch since the final look is not as black as it should be. It also made taking pictures of the final clock a bit tough since even with modest lighting the glare was horrible.
The gear arrangement is as follows:
  • 9 tooth motor gear
  • 72 tooth minute gear with a 24 tooth secondary
  • 72 tooth intermediate gear with a 18 tooth secondary
  • 72 tooth hour gear
To achieve the correct timing the 9 tooth motor gear is advanced 4 steps every 9 seconds. By moving 4 steps at a time the motor routines can be simple since the motor is always at rest with the same coil energized.
45 comments
1-40 of 45next »
Oct 21, 2010. 7:27 AMREA says:
using the picture, i was able to crudely model the clock in Inventor.
here are the files
Oct 22, 2010. 12:59 PMREA says:
i kept trying those files to get the proper dimensions but they wouldnt work in DWG Viewer, Inventor, or AutoCAD (all the most current version).
Jan 24, 2011. 9:06 PMdurgledoggy says:
DXF files should open in AutoCAD with no trouble. To be honest they should open in nearly any CAD program. Seems like it's been saved by a third party app, so probably doesn't quite meet the DXF "standard".
Try RECOVER or DXFIN and see if that can drag it through.
Suggestion to abbtech, try using DWG trueconvert to get a decent file.
I like this project. Thanks.
Apr 14, 2010. 10:29 AMRob K says:
For some reason I cant get any of the DXF files to open on this computer. Photoshop CS2 , AutoCAD 2009, Inventor 2010.
Ill give it a try on the schools computer.
Oct 5, 2010. 6:50 AMREA says:
AutoCAD 2011 cant open them either.
Apr 14, 2010. 10:17 PMRob K says:
I was only able to view the DXF files on AutoCAD, and Inventor when I imported them into MicroStation then resaved them as a DXF in another folder.
Weird.
Apr 14, 2010. 11:03 AMRob K says:
Same on the school computers also. Autocad 2008.
Invalid or incomplete DXF input -- drawing discarded
Aug 9, 2010. 11:27 AMmathman47 says:
I have the kit from Alan, but haven't built it yet. Glad I ran across this I*. I've been trying to come up with ideas for colors and am thinking now about using one of the Krylon spray cans for a textured effect. Do you know if you can put another color on top? Great job. I love clocks. As I sit at my desk I can see 12 and I have a few to build yet!
Mar 27, 2010. 5:25 PMEnder2007 says:
How do you cut the gear?
Mar 28, 2010. 1:02 PMEnder2007 says:
Thank you for the reply.
I should have been clearer with my question.
I would love to to the same with a CNC but I lack experience.
What kind of CAD did you use to generate the gears?
And how did you process them to the CNC?
Thanks.
Mar 29, 2010. 6:17 AMEnder2007 says:
Thank you so much!
Going there right now...
Mar 14, 2010. 3:00 PMDoc Holliday says:
As a first step, how do I create really accurate gear patterns without expensive tols and training?
Jan 2, 2010. 6:20 PMjohn3f says:
The step motor used in this project is a "unipolar" type step motor, not a bipolar one. Bipolar step motors dont have a "common, ground, +V, coil split etc.." connection. Also it's not easy to drive a bipolar step motor. A bipolar stepper requires h-bridge circuit and 8 transistors for the coils to be driven.
Jan 3, 2010. 4:48 AMjohn3f says:
Great. The project is really awesome.
Oct 28, 2009. 5:53 PMknife141 says:
Very nice project!  In terms of getting a rusted metallic look on wood, I've had good luck spraying the parts with flat black, then just lightly dusting with bronze metallic paint.
Oct 25, 2009. 10:29 AMKiller~SafeCracker says:
Good job. Now if I could just get the gears I would build.
Oct 25, 2009. 4:23 AMnewtonn2 says:
 Very cool clock! Excellent JOB!
Oct 22, 2009. 6:41 AMrobotguy4 says:
You should maybe add two stationary pointers to the mix...  For accurate time reading...
Oct 21, 2009. 8:30 PMbenthekahn says:
 if you put sea water on steel it will rust it over night.
Oct 22, 2009. 7:10 AMbenthekahn says:
I said that to let you know that you could just cover the gears with thin steel sheet, and rust it over night for very little cost.
Oct 22, 2009. 2:25 PMKoosie says:
Woah, seriously awesome!
Looks a bit like the twin cams on a DOHC straight six.
Oct 23, 2009. 7:34 AMRe-design says:
First Class.
Oct 22, 2009. 10:25 AMDoldrum says:
 I don't need to tell you how awesome that is.
Oct 22, 2009. 8:27 AMcarlo$ says:
Outstanding man.  The only feedback I have is: you need a reference point on each gear  so that anybody that looks at your clock can read the time easily.
Oct 21, 2009. 6:55 PMChicken2209 says:
 Saw this on my make rss (i think)
Really interested me mainly because I've had the idea of a planetary clock but given very limited budget and supplies i'd be limited to cardboard and an exacto knife.  MDF seems slightly better though... What programs did you use to make the gears?  The closest i had was inkscape that has a star tool that can create a gear looking shape that could function but i think its mainly for looks and not functionality. I like the use of the floppy drive motor too.
Oct 21, 2009. 8:04 PMChicken2209 says:
How was it cut?
1-40 of 45next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
46
Author:abbtech(Hacked Gadgets)
You can see my blog here: http://hackedgadgets.com and my personal site here: http://alan-parekh.com
