3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Geared Motor Servo Conversion
hey!
This is a quick little project i did one night after work!
I was itching to solder something, so here it is! My cure for boredom!
You will need the following:
1 x Servo
1 x Screwdriver
1 x Soldering iron
1 x Wire snippers
1 x X-acto knife
1 x Connectors of your choice
enjoy!
Step 1Take It Apart!
Take It Apart!
Alright!
Take your servo apart!
Remove the four screws at the bottom. Get rid of the servo wires (snip or de-solder, your choice)
Do the same with the 3 wires connecting to the motor.
5 comments
Dec 19, 2011. 6:17 PMsdfgeoff says:
Or you can leave the electronics in, but cut the arm of the potentiometer.
Then you can control it like you would a normal servo, and use it as a motor without needing to make an H-bridge.
Jan 11, 2012. 5:15 PMGelfling6 says:
I have to agree with sdfgeoff.. You needn't go as far as massive rework, when the majority of the work is already built-in.. Just a matter of minor modification to the main drive gear to remove any kind of 'stop' tab, and removing the potentiometer, and replacing it with a pair of 2.2K resistors in a "W" (or "M ") wiring, connecting the two resistors in series, connecting the free ends to the outer-connections for the pot, and the center of the two, to the wiper connection on the servo board. Then, simply sending a PWM train signal to the Signal pin of the servo, and simply supplying 4.5-6V to the servo power pins. Unless you really want to go as far as the H-Bridge, and have direct control of the servo motor.. Just seems a lot of extra effort to rebuild the mouse-trap, so to speak.
Jan 12, 2012. 2:57 PMsdfgeoff says:
It just depends what use you have in mind.
Some mirocontrollers may not be able to output a pulse necessary to drive the servo without stopping all other processing (the old basic stamps had this problem I think), and so it is then better to use an H-bridge.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:max_fraser
