loading
Step 6: Construction - Front Nose - Part 1
The front section of this particular gun is fairly complex and building it is going to involve more then a few different pieces.  I'm going to break this down into a few steps so there isn't too much information on a single page.  One of the details of this gun that I really like is the shape of the barrel.  Unlike almost every gun ever made, the Digger barrel in not round.  It is instead an oval shape, which I personally really like.  You can see this if you go back and look at some of the still images of the ingame gun.  The nose construction consists of two main pieces.  I'll label them, front and back.
The trick to building complicated shapes like these is trying to break it down into as many smaller, less complex pieces as possible.  I always find that it is much easier to build this way, and add on each new piece as you go.  This has been working really well for me so far, and I recommend this as a good rule to follow.
Back Nose Core
I started with the back piece and traced out the pattern for half the barrel onto 1/2" MDF 'several' times, cut them all out, and glued them together.  Picture 1 shows the left and right sides.  The surfaces were sanded smooth on a belt sander.  To make painting a little easier,  I glued thin sheets of styrene onto the inside of each piece.  By doing this, I won't have to apply several coats of primer, sanding between each coat to get a smooth surface.  You can see that the inside of the barrel is white in picture 6.  This piece is now the main core that all other pieces will attach too for the complete nose.
Front Nose
The next step was to create the front portion of the nose.  Due to the grooves and beveled edges on this piece I decided to build only half of the nose and cast the 2 halves that I will glue together.  I started in the same way by cutting out various pieces of wood at the different sizes needed according to the blueprints, picture 2, and then glued them all together, picture 3.  I used Apoxie Sculpt to bevel the necessary edges.  The Apoxie Sculpt is red in picture 4.  Like the back part of the nose I also covered the inside of this piece with a thin sheet of styrene for the same reasons as before.  Pictures 5 and 6 show this half aligned to the back piece.  The next step was to coat it in layers of primer and sand it all smooth.  I then made a quick mold of this piece and cast the 2 halves from Smoothcast 300.  I glued these together with super glue, picture 10,  and will smooth out the edges with bondo and sandpaper.
Back Nose Builtup
Moving back to the back portion of the nose.  I needed to build the additional elements.  Using the blueprints as a guide I cut out more pieces from MDF to build up the base of the larger curved surfaces, picture 9.  Like before I glued them all together and sanded them smooth.  Now I did something a little differently here than what I've done in the past.  Once this nose is finished, it is going to have a lot of deep gashes and grooves cut into the surface, and to make it a little easier later on, I decided the best way for me to do this would be to cover these new pieces in thick styrene.  I would then be able to take out chunks, hopefully with good results and minimal cleanup.  My heat gun was the ideal tool for bending these pieces of plastic.  So I cut down several pieces of styrene and glued them to the first side of the pieces.  Using the heat gun I then slowly warmed up the plastic where it needed to be bent around the surface and glued them down as I went.  As a word of caution, it is very easy to overheat the plastic or unevenly heat it and end up with an ugly crease right in the middle of your bend.  I ended up doing a lot of tests before I found the sweet shot for bending these plastic pieces.  Picture 10 shows these all covered in their styrene sheets with the front edge beveled.  Next l added in the small details in picture 11 by drilling various sized holes in thinner sheets of styrene, and then layering them together to create the effect shown.  I continued along this process until all of the pieces were constructed and in place.
Since the casting for this project is minimal I'm not going to go into detail on how to do it here.  I buy all of my casting materials from Reynolds Advanced Materials.  They have a location right near where I live, which is extremely convenient.  Their website has a serious abundance of information on casting and mold making.  If your interested in learning more about these subjects, I highly recommend you check them out.  I also go into more detail about casting in my Portal Turret Instructable.
Materials Used for This Section
MDF
Wood Glue
Styrene Plastic
Apoxie Sculpt
Super Glue
Rebound 25
Smoothcast 300
Tools Used for This Section
Band Saw
Belt Sander
Drill Press
router
Dremel
Clamps
<p>WOW!!! Amazing</p>
<p>How did you sand the weathered metal paint job without going all the way through the paint? I tried that with a nerf gun. And would always get to the plastic under the paint.</p>
cool but are you gonna make anymore weapons from gears of war 3?
<p>Unlikely. Though new stuff is in the works!</p>
If you made me one I would pay you $750 or more
Sorry I'm not making any more of these.
inspiring. wife's going to kill me.
Congratulations on being a finalist in the Halloween contest!!! Can&rsquo;t wait to see if you win! Good luck!
Wow! Incredible great job! <br>How many hours do you have in this great project! <br> <br>If they come out with a movie, I hope your on the prop list!
This looks great! Ive played all three of the gears games and now i feel like making a replica after seeing your instructable. Who did you contact to get your 3D model?
Another great one =) Lovely
you should make and sell these<br>
Thanks for the compliments everyone. It's amazing to see such positive reactions to this project!
Brilliant item, if only the page would stop bugging i could actualy vote:(
Thanks, and please Keep trying!
Managed to do it by loading this website in Chrome, then going to the comp main page, at least i finaly got my vote in, Good Luck with it man, you deserve it=)
Wow, I've never played any of the Gears series, but this is awesome and stands on it's own!
You two did an amazing job. People at the office (EPIC) really seemed to love it! ;D
I never played Gears of War, but I can appreciate your amazing result! It looks real, not like most replicas, the photo of step 20 is better then an excellent 3d render!
Thats one of the coolest things i've ever seen. And i truly would like to work with you peeps from the game dev industry. Such a shame that Brazil sucks when it comes to games. And i hate soccer.<br><br>Yeah, very impressive prop, thats what i meant!
Amazing work, Very fine detail. The extra steps taken to get those fine details shows the pride you take in your work. Very Nice Job !!!!!!!!!!!!!
AWESOME! (but will it shoot? :) )
I saw your work on Epic's website and on Facebook. You did an amazing job. Just as good, if not better than the GoW replicas made by Triforce. You definatly put a lot of work into making this and I love how detailed it is. I hope you win the contest; you definatly have my vote.
Welp, umm... damn. <br><br>Best gun model ever pretty much. Keep up the good work, etc.
wow!!! excelent work, I want one for me
exelent work, finest details and gorgeous style, very very awesome, this gun reflects the hard hours of work, (Y)
Speechless.
WOW!
The reason there are no comments is because everyone is speechless about your work! This is a truly amazing project and major credit to you!
About This Instructable
26,223views
230favorites
License:
Bio: I'm a 28 year old Nerd working as an animator in the game industry in Los Angeles. When I'm not in front of ... More »
More by CitizenSnips:Gears of War 3 - Hyper Realistic Digger Launcher Replica Building a Portal Turret with motion controlled audio and lighting
Add instructable to:
