First, work a 4-bead wide strip of herringbone weave. Twist, join the ends, add a hanging loop, and voila! A geeky, yet elegant earring.
Remove these ads by
Signing UpStep 1Materials and tools
- size 11/0 cylinder beads (e.g., Delicas) in two colors for the edge and middle of the strip (I used matte dark gold and matte rose)
- a pair of French hooks or kidney wires, to coordinate with beads
- short beading needles
- Nymo or other nylon monofilament thread, D weight, to coordinate with beads
- a sharp cutting device (mine is airplane-safe)
First, in the fourth step where it says to "pass back through the two edge beads" do you mean the very last two? Because it only works if I put it through the two before the last bead if that makes any sense.
Also, something that may have been an issue for me is that I may have kept turning and flipping the beads as I was working on them and kept tangling my string so when I try again I'll keep it the same way at all times but in the fifth step where you "turn the piece over" do you flip it over or rotate it like 180 degrees or something?
Sorry about all the questions, I'm just really confused and would love to complete these earrings and put my beads to good use.
Thank you = )
If I understand you, yes, in step 4 you shouldn't pass back through the new edge bead you just put on the needle. Then it would come off! The point is to loop around one of the existing beads so that the thread can come back out the top of the new edge bead, in the right position to add the next row. To be honest, there's more than one way to do it---you just don't want to add too much extra thread that kinks up the beads.
In step 5, I mean turn it over so that the working thread is back at the top right hand corner of the piece. If you are right-handed, it's easiest to work right to left. Does that make sense?
I'm glad you like the pattern! ! Let me know if you run into more problems.
Janet
