3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Moebius strip earrings
Step 7Joining the ends
Joining the ends
Now for the fun: Joining the ends! You will basically work one last row of herringbone to connect the two ends. The twist is that you will work from right to left on the beginning of the strip, and from left to right on the end of the strip.
Pass the needle through the two beads on the opposite edge of the beginning of the strip, in the herringbone pattern.
Snug the ends up next to each other.
Then pass through the two middle beads at the end of the strip, in the herringbone pattern.
Then pass through the remaining two beads on the beginning of strip, in the herringbone pattern.
Join the edge by passing the needle through several edge beads on the end of the strip.
Carefully pull tight, easing the thread along, and you have a beaded Moebius strip!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:davisjan
