Now I've had the idea for this Instructable while browsing around and falling on the e-shop of some kid my age who was selling PCB and electronic component jewelery: CMOS earrings, resistor pendants, and the like. Since then, I've been trying to integrate old hardware and electronic junk to my daily dressing, without much success. It wasn't until I stumbled on a pile of old processors that I finally clicked on what would be cool, and yet not be a total pain wearing: a processor belt buckle.
Although not useful in itself, this thing is nice showoff material for those times when you get together with your geeky homedawgs.
It's simple really: all we are gonna do is take a proc, brutalize it up a bit, then solder it to your standard issue slider and casing type buckle used with strap type belt.
Remove these ads by
Signing UpStep 1Materials
-Belt buckle with a flat face. This can be either be the ones that clasp or the ones with the tightening pin in them... excuse my lack of more precise wording. There are pictures available at the bottom.
-Processor, the older the better. I used two Socket 7 Intels of the code name P5 era. According to pictures I have seen, and the size of the heatsink in an old box I have, the K6 series should be big enough, so rejoice, AMD fanboys. In this Instructable, we will be using a P54C, a pretty high end chip for the time, which used to sport 200 mhz and MMX.
-Some acid flux paste. If you have a soldering iron, you probably already have this.
-Solder. I used 60/40, I am guessing that 50/50 would work too, but any lower will bust it in my opinion. I used full metal solder, but if you don't have any flux you might want to try resin core. I haven't tested that though.
AMD architecture is a little out-dated, and the lack of SSE2 support pisses me off with my sempron because I'd like to try installing OSX on it, but not going to happen, that's sad that my thinkpad with it's 1.5ghz pentium D will run OSX and my 2.0 sempron will NOT.
But I will always stick with AMD until they prove otherwise, for a good example, I notice music skipping a lot LESS on my sempron when I've got the processor loaded up, unless it's reallllyyyy bogged down, otherwise It's treated me better than intel ever has, but then again I haven't had the chance to own a dual core intel to know for myself how much they have really improved since.
