3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Geeky Circuit Board Earrings
Step 2Cut the Board
Cut the Board
Next you have to select an area of the board to use. It helps if you use a board with duplicate areas. I used an array of little surface mount components. I would recommend only using surface mount boards, as regular ones will be bulky. Keep an empty area towards the top to attach the hooks.
After selecting the area, cut out the board. I used a bandsaw with a wood blade because I'm too lazy to change blades. It didn't splinter, so I guess it worked. Test it on a scrap board. And of course, don't cut off any body parts. As my dad says, a blade can't cut you if your fingers aren't in front of it.
RaNDoMLeiGH brought up a good point that I hadn't thought of in the comments. Read her comment for a better description, but the basic point is, WEAR A DUST MASK! The dust produced by sawing through silicon can give you a huge assortment of unpleasant respiratory problems, namely lung cancer and silicosis. Wear a mask, use a saw with a vacuum setup, wet it down, whatever you need to do to avoid breathing the dust. It's a much bigger issue than solder. This goes for the next step, too.
4 comments
Jun 16, 2010. 9:16 PMcrummett says:
I tried this with a wood blade like that and rendered my blade unusable after cutting 4- 5" circles. Of course, I was cutting through some pretty heavy duty components! Next time I'll try a hack saw blade.
Mar 8, 2008. 8:26 AMDavid Cousins says:
I like it. I going to make some for my daughter.
Jun 10, 2008. 5:26 PMNetReaper says:
Make sure to protect her from any lead solder in the circuit board.
Mar 19, 2007. 9:28 AMiamnotsancho says:
Those are sweet, I'd buy'em if if saw them for sale.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
99
Author:CameronSS
I'm a geeky college student without enough free time or funding to do most of these Instructables...sigh... Topeka is my hometown. I'm at school in Wichita about 80% of the time, but I like Topeka be...
more »
