I initially wanted it to have usb data so I can copy data between phone and computer but the phone didn't really like the way I have set up the ribbon cables and molex interface so it does not allow me to transfer data. Charge only. This is not a big deal for me but if you want data on the dock, the molex connectors must not be used. I used the molex because it looks way cooler than a usb cable directly on the stick of ram.
Remove these ads by
Signing UpStep 1: Get materials
Hard drive. (I used a old broken one that was made in 2001)
RAM, I used a old ram (SD ram made in 2001)
Micro usb male
3.5mm headphone 3 or 4 pins male
Epoxy (black preferred).
angle grinder
Torx screwdriver T6
Heat gun
Drill and drill bits
Dremel equivalent
Eye goggles and mask
I did not have black epoxy but wanted a black appearance. I used some toner from a broken laser printer and mixed it in with my blue/red epoxy to make it black. careful with the toner particles though it will go straight through a standard face mask because it is so fine.
Visit Our Store »
Go Pro Today »
yeah, the 3.5mm is soldered, it is routed to the slave/master pins and I made a female header to 3.5mm female plug. I did it this way to make the hard drive i/o look unmodified.
If you meant actually adding speakers to the dock, then, no because I won't be using it (because it is made for the office I work at and they probably won't like me playing music through loudspeaker there).
