introGel-O-Shot INSIDE A Banana!
Make a Vodka Gel-O-Shot INSIDE A SEALED
Banana!
I'll show you how to use Osmotic Pressure to gel the inside of a banana.
This also works as a great magic trick for your next party.
Remove these ads by
Signing Up.
step 1What you need
You'll need:
Ethanol is a great solvent for biological molecules.
The sugar will encourage coagulation of the liquefied banana interior.
Refer to step 4 for a detailed scientific explanation.
- An almost ripe banana
- Some Vodka (Better quality = better results)
- 1/4 to 1/2 cup sugar
- Tupperware©-like plastic container
- Refrigerator
To Download the PDF or View All Steps, Become a Pro Member » |
if i remember correctly, this thing is not an osmotic pressure system. it is just normal osmosis. osmosis works by allowing ions to travel from an area of high concentration to travel to a area of low concentration to cause equilibrium. equilibrium is the "balancing" of the ions on both sides of the membrane (in this case the banana peel) im not sure of the EXACT science of what permeates the membrane in this expirament but im sure it is diffusion.
http://www.okc.cc.ok.us/biologylabs/Images/Cells_Membranes/diffusion.gif
osmotic pressure uses pressure to force ions from a lower concentration to a higher concentration diluting the higher concentration thus achieving equilibrium.
http://www.biologycorner.com/resources/osmosis.jpg
How ever on wikipedia wikipedia you can read some chemicals that are not very safe...
