loading
Make a Vodka Gel-O-Shot INSIDE A SEALED Banana!
I'll show you how to use Osmotic Pressure to gel the inside of a banana.
This also works as a great magic trick for your next party.
Step 1: What You Need
You'll need:
  • An almost ripe banana
  • Some Vodka (Better quality = better results)
  • 1/4 to 1/2 cup sugar
  • Tupperware©-like plastic container
  • Refrigerator
The banana needs to be almost ripe in order for the skin to become semipermeable enough to allow the Vodka (ethanol) to pass through it via Osmotic Pressure.
Ethanol is a great solvent for biological molecules.
The sugar will encourage coagulation of the liquefied banana interior.
Refer to step 4 for a detailed scientific explanation.
Step 2: Put 'em Together
Add Vodka to the banana in the plastic container. Fill it up the entire banana is covered.
Pour in the sugar and mix it until it dissolves completely.
Step 3: Cool Your Jets!
Put the whole thing in the refrigerator for a few hours, uncovered.
It will take anywhere from 4 to 12 hours, depending on the quality of the Vodka, amount of sugar, and the temperature of your fridge.
You'll have to try it a couple of times to get it right. If the banana is only partially gelled, leave it in for a couple more hours next time.
Don't leave it in there for too long, though. It will turn into a runny mess!
Step 4: Scientific Explanation
So what's going on inside that banana?
In this experiment we have both water (H2O) and Vodka (ethanol).
Because the peel of the banana is a semi permeable membrane, it allows the ethanol to pass through it. This is caused by the difference in the concentrations of salts inside and outside the peel.
High concentration of potassium and other salts inside the banana and the low concentration of salts outside the banana will encourage the ethanol to pass through the peel into the banana to equilibrate the system.
According to an article in Experimental Botony, 1980, volume 31, number 4, pages 975-982, the banana pulp will begin to leech electrolytes. The high concentration of potassium inside the banana will drop. This will also help the system come to equilibrium.
The coagulation of the inside of the banana is readily dependent on the temperature of the system.
Ethanol is a great solvent for biological molecules. It will dissolve some of the inside of the banana, but at the same time all the lipids will not go into solution. So it is no surprise that the ethanol makes the banana become 'softer.' It is essentially liquefying the inside.
In the process, the transition temperature inside the banana has raised above the temperature in the refrigerator. Dropping the temperature will cause the lipids and the ethanol solution to congeal.
Hence the 'gel-o-shot' like state.
For more information regarding Osmotic Pressure and Ionic Equilibrium, here are a couple of great books on the subject. (Via amazon.com)
The Osmotic Pressure of Biological Macromolecules by M.P. Tombs & Arthur R. Peacocke
Ionic Equilibrium: Solubility and pH Calculations by James N. Butler
Step 5: Enjoy!
Take it out of the fridge and check the firmness.
You should notice right away that the banana feels very gelatinous inside. If it's not, then the alcohol hasn't had enough time to pass through the banana membrane and begin to liquefy the inside.
The banana will also have browned quite a bit from the cold spell. That is normal and will happen to a plain banana as well. In this experiment, the browning is accelerated by the leeching of electrolytes.
Use a knife to cut a notch right at the base of the stem, then peel it open to reveal your tasty alcoholic treat!
How long does it stay like that in ambient temperature? Or does it need to be eaten right away?<br><br>The reason I ask, it would be a great prank to play on my coworker... who likes to eat his banana in the office in the middle of the morning... I'd just switch his banana with a jello banana. However, that would imply that it would sit there for a while in office temperature...
I see in the photo you poured the vodka into the sink, are you able to pour it back into the bottle and keep using it for other drinks, rather than just pouring it away?<br />
osmosis is diffusion with water. i think the correct term you are looking for is diffusion.<br/><br/>if i remember correctly, this thing is not an osmotic pressure system. it is just normal osmosis. osmosis works by allowing ions to travel from an area of high concentration to travel to a area of low concentration to cause equilibrium. equilibrium is the &quot;balancing&quot; of the ions on both sides of the membrane (in this case the banana peel) im not sure of the EXACT science of what permeates the membrane in this expirament but im sure it is diffusion.<br/><br/><a rel="nofollow" href="http://www.okc.cc.ok.us/biologylabs/Images/Cells_Membranes/diffusion.gif">http://www.okc.cc.ok.us/biologylabs/Images/Cells_Membranes/diffusion.gif</a><br/><br/>osmotic pressure uses pressure to force ions from a lower concentration to a higher concentration diluting the higher concentration thus achieving equilibrium. <br/><a rel="nofollow" href="http://www.biologycorner.com/resources/osmosis.jpg">http://www.biologycorner.com/resources/osmosis.jpg</a><br/>
hmm, I always thought that osmosis involved liquids and diffusion was gases only?<br />
&nbsp;mmm tasty tasty science
So I found a nice banana, yellow with a hint of small brown spots, no greenish tints anywhere. I poured a relatively cheap import vodka into an IKEA dish untill the banana was just covered (floating a little, the top of the banana was always just above the surface though) I then saturated the vodka with sugar, took about 4 big spoons, couldn't dissolve it all. I then placed the container in the refridgerator, which is only about 2 degress celsius. After about 24 hours I took it out, and peeled it... Still a normal banana. So what did I do wrong? :S
That's odd. It could have been the cheaper Vodka. What proof was it? The higher the proof, the more ethanol content, which is what you need for this to work correctly.
Proof? According to the label on the bottle it was 37,5% vol. alcohole...
&nbsp;proof is twice the percent i.e. bacardi 151 is 151 proof but %75.5&nbsp;
so if u just want a gelled banana, u could use pure alcohol. just dont eat it.
sweet do they taste alright i like bananas and i like vodka
cool "alcholic bannas" good one
that looks really effing disgusting, but pretty damn cool<sub> good job bro</sub><br/>
sweet. now trig will be a lot better for me
too... many... scientific... words...
Interesting refrigerator contents; water, beer and banana shooter. Not a lot of nutritious clutter in the way, I like it! Got to admit the banana does look rather gross afterwards.
Wash well the banana.... it can be full of Herbicide.<br/>How ever on <a rel="nofollow" href="http://en.wikipedia.org/wiki/Bananadine#Chemicals_in_bananas">wikipedia</a>wikipedia you can read some chemicals that are not very safe...<br/>
nice one i remember my student years
It seems like a waste of Vodka to use that much for one banana. Can you use the same liquid for more than one? or does it go bad?
the stuff you poured down the drain, was it gross tasting? inalcoholic? why did it go down the drain? would it be poissible to check and see if the banana gelled and if not the put it back in for awhile?
Bizarre! If it weren't for that whole alcoholic bit I'd make one just to turn a banana into gelatin.
Does this work with any other fruits? Maybe the Kiwi or a peach? I really hate bananas.
Nice istructable, and quite cool :)
so... what's the science behind it?
I've updated this instructable with the scientific explanation.
Sweet!
Jello© is a registered trademark, which is why this is called Gel-O-Shot.
I really don't think jell-o will sue after all its pretty much free advertising
You would be surprised how aggressively companies protect their trademark. They've gone after popular bars to get them to quit advertising Jello Shots. They've also made it illegal to sing the US Happy Birthday song in restaurants, which is why Red Robin and such places have their own tune.
good instructable by the way, nice and clear, easy to follow, nice pics to. hmm looks a little wierd though (final product) i bet a nibble of that will put you over the legal BAC hehe. i would try it if i was of the drinking age
I'm not allowed to drink Vodka.
That's a shame. The ethanol (Vodka) is what makes this work.
That's what I was thinking too. Is there some way to do this without vodka?
Yea... You could use Bacardi 151 or Wild Turkey. :)
Not that I know of. The Vodka and sugar are what makes this trick work.
All that wasted booze, lol I can't even drink<br/><br/>You should listen to <strong>You drink you drive you spill your beer by: NOFX</strong><br/>
does it still taste bannanaish once it's done? or...more like pure gelatenous vodka?
It tastes like a Banana Jello© Shot!
I've just updated this instructable with a scientific explanation. Several people have emailed me asking for it. Enjoy.
would it work if you get all the alcohol out of the vodka? just heat it up on something outside and eventually the acohhol will all be gone
No. The Ethanol (Vodka) is required for liquefying the inside of the banana.
Wow...that was f***ing disgusting looking! Nice narration voice though. I feel calm and disgusted now.
About This Instructable
25,730views
45favorites
License:
More by NK5:Confetti Bomb Prank! Make a cool hologram illusion! Make your own Lightning Globe!
Add instructable to:
