loading
Hi all,
This instructable is based on the two links below and was put together to test the durability of the gelatine prosthetic, how to glue the prosthetic in place and also to test how make-up adhered to the gelatine. It enabled me to learn by making a few mistakes which I have shown and also re-use the gelatine once clear of makeup and glue to keep the cost down when practising prosthetic construction and application.
Is a very low cost gelatine prosthetic. The entire cost was approximately 5 euros. It is less likely to cause any skin irritation if you are allergic to rubber latex as there is less surface area covered in latex apart from the edges of the bald cap but still do all the usual tests with the materials to check for allergies prior to application.
The whole process takes about an 2 hours once you are used to applying basic prosthetics and you can re-use your negative mould multiple times as the gelatine washes out easily, as long as your Plaster of Paris mix is strong. Normal ratio is Plaster of paris 2 parts to 1 part water. Simple plastic cups are the best way to measure amounts required.
The most important part of any prosthetic is to ensure you have thin edges for effective blending to the skin. This example is a little rough and needed more blending with regards to the makeup application and edges of the gelatine but it was done just to show the process and less emphasis was put on realism but it's still fairly effective and hope it gives you the basic idea.
Please be aware: Gelatine is extremely hot when melted (like hot toffee) therefore please don't apply it directly to the skin or you may create a permanent special effect prosthetic.
Before you start check out the original gelatine prosthetic instructable for some extra hints and tips and the original you tube video where it all started.....
https://www.instructables.com/id/Using-gelatin-for-...
http://www.youtube.com/watch?v=2AoMl8ttowI
Enjoy !
Step 1: Time Lapse Video of the Entire Prosthetic Application Process
not to be picky,but I would have covered up my ears with the bald cap to make it look a little bit more scarier. But its your prosthetic application not mine! ;D
I'm not sure why but every time I get down to the part where you used the wire to scrap the clay, I get booted out of the Instructables APP. Not sure if it's my iPhone, the App, or if there's a problem with the site. Have you had anyone else mention it? <br>Btw, love your work. :-)
<p>Hi JoLoveN ... just sent you the PDF hope it opens ok ;)</p>
<p>Hi JoLOveN...if you send me a private message with your email i can save it as a PDF and send it to you if that helps :)</p>
<p>Please check out some of my videos and 'LIKE' if it's been informative ;)<iframe allowfullscreen="" frameborder="0" height="281" src="//www.youtube.com/embed/y7tgkXSSUX0" width="500"></iframe></p>
amazing, it as a scary feel but also a funny feel :)
<p>Yeah james.rasa....it's a strange mix glad you like it, give it a try and post any findings :)</p>
<p>Hi all,</p><p><br>Hope you have enjoyed the instructables so far and thank you to all the lovely people who are following me ....<br><br>Please check out my YouTube page and 'LIKE' the videos and 'SUBSCRIBE' to see more videos and pics....<br><br>Thanks<br><br>Steven Harris FX (The Animator)<br><br><strong>WARNING: THIS VIDEO COULD BE A LITTLE SCARY FOR CHILDREN</strong><br><br><a href="https://www.youtube.com/watch?v=YNNhYMZLNh4" rel="nofollow">https://www.youtube.com/watch?v=YNNhYMZLNh4</a></p>
Very nicely done though btw
<p>Thanks KemikalzAreFun</p>
If you take a little latex or silicone and kinda stipple it on with a sponge, it will make the shine on the gelatin prosthetic look less shiny and make it look more realistic after paint.
<p>I have also used pros aide for the same effect...good advice mate!</p>
About This Instructable
12,486views
114favorites
License:
Bio: Hi all, I am currently working towards my lifelong dream to become a special effects makeup artist in film and TV. I am learning lots ... More »
More by The Animator:Avatar Special Make-up Effect Storm Trooper make-up effect time-lapse video The thermal burn video guide - Steven harris FX
Add instructable to:
