Generate Story Character Names with the Teensy by sail4sea
Step 9: Close the Box
Close everything up, being careful not to pinch the loose wire.  I made the wire a bit long, but my enclosure had plenty of room inside.  Make sure you have the correct SD card in the SD adapter, because it will be a real pain to open the unit to change the SD cards.
Screw in the screws to the bottom of the enclosure to keep everything together.  For an added touch, I put rubber feet on the bottom of the enclosures over the screws.
Now plug the unit in and test it one more time for good measure.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
