3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Geodesic Dome Greenhouse
Step 27Staple Plastic and Cut off Extra Plastic
Pull the plastic tight over one triangular section of the dome. Staple just enough to attach the plastic to the wood on each leg of the triangle. Then go back and staple the plastic to each leg of the triangle, stapling about two inches apart. As you do this, continue to smooth the plastic to get the wrinkles out. It helps to fold the excess plastic on top of itself as you staple it onto the wood. Continue by covering as many triangles as you can until you have used up the plastic sheet. When your first section of plastic is securely attached, cut off any excess that does not completely cover a triangular section of the dome.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
16
Author:yes2tech
