Geodesic Dome Greenhouse
 by yes2tech
Featured
Step 6: 5-Way Connectors
1) Begin by cutting thirty strips that have seven holes each.
2) Once you have all of these strips cut, use a vise to bend the pieces after the first hole from one end. Make 25 degree angles on all bends. You must do this for all thirty strips.
3) Once all of your strips have been bent, it is time to assemble them. Line up the first hole for five of the strips and connect them with a bolt and nut. For assistance on how they should be assembled, refer to the picture.
4) Repeat step three until you have a total of six connectors.
tswill2 says: Jul 21, 2011. 10:18 AM
At this point I would add an additional 3 hole strip under each bolt for hanging interior lighting / etc.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
