3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Geodetic greenhouse (low cost)
Step 2The joints
The joints
One of the issues I had with my fairly small green house was that for larger domes it is easy to drill the ends of the struts and put a bolt through. But for my much smaller - 3/4 inch square  - struts this wasn't going to work. So I devised a quick assembly method using some plastic plumbing pipe and some elastic bands.
A small hole was drilled vertically through each strut and a nail allowed the fixing of the elastic band. The bands were cut from an old bike inner tube.
3 comments
Oct 21, 2011. 11:45 AMlotusduck says:
That should be sort of sturdy, but rubber does degrade under heat and sun, and that would probably be your first point of failure in the whole construction.
Sep 25, 2011. 1:21 PMhgilman says:
i built one 2 years ago with thin bamboo for the sticks and for this part i bought a 6 dollar hose. then i just cut the whole hose into 5 inch sections. for the 6 pointed stars i took 3, 5 inch sections and drilled a hole through them and put a bolt through the 3 holes. then i screwed each point to one bamboo. for the 5 pointed stars i just connected 2, 5 inch sections and one 3 inch section with a bolt and nut
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
82
Author:rickharris
Retired technology teacher - 2 kids, aged 62 I have an Hons deg in Design and Technology - 28 years as Computer systems engineer Trained as Electronics engineer in the Royal Air Force
