3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Geodetic greenhouse (low cost)
Step 3Putting things together
The struts were cut from the pallet wood using a band saw roughly 3/4 inch square (19mm). This is tedious and your not going to want to do it by hand so if you don't have access to a band saw or something similar buy wood that is the right size.
Perfectly good domes are made from Garden canes and provided they are wide enough you could use this method of connecting them.
The lengths of the 3 types were cut from the Desert dome information and the ends drilled.
Sitting on the lawn all of the struts were laid out and then connected. I chose (perhaps unwisely) to build from the top down because this means you have to lift the full weight of the dome to add more struts.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
82
Author:rickharris
Retired technology teacher - 2 kids, aged 62 I have an Hons deg in Design and Technology - 28 years as Computer systems engineer Trained as Electronics engineer in the Royal Air Force
