Step 4Laying Out The Lamp Design
On the lamp shade design drawing the solid red lines are cut lines and the broken blue lines are fold lines. The little piece on the right edge will be referred to as the flap.
Draw the pattern on the backside of the paper with a pencil. Using a very sharp blade and the straight edge cut where appropriate. Use the indenting tool to dent the paper along the fold lines. Make sure all the cuts go right to the corners and the dents are well defined. If you do not have deep enough dents in the paper it can be difficult to get a clean fold.
Now carefully erase the pencil lines.
(The zip files are .jpg versions of the lamp shade design drawing in both inch and centimeter scale. Please note that the two designs are very slightly different, and I built mine in inches. If you go metric you'll have to adjust other parts on your own.)
comments
Add Comment
Add Comment
