Step 5Folding The Lamp
Using a straight edge, table edge, or other method, fold the 3 corners that don't have the cut out design and crease well. Unfold enough so the paper is relatively flat.
Now comes the tricky part...
Starting with the top and bottom creases fold the paper as far as it will go without putting undo strain on the paper. With this accomplished you should be able to start pushing the design into the body of the lamp.
Standing the shade upright at this point can help. Doing one at a time use the indenting tool or your fingers to push and press the paper into position. Don't do any one all at once; In order to avoid unwanted creases, tearing, or curved paper you have to do a little bit on each until the folds are established.
Once everything is going the way it should go, you can lay the paper flat on the table and carefully push it down (all the while pushing and pressing the individual folds) until the whole thing is flat. Now crease every fold very well, if you don't the lamp will tend to be out of square.
With the lamp folded over place a piece of double stick tape on the outside of the flap. If the tape has a protective strip on it, leave it in place for later. If you put a big flat thing on top of the lamp to press it down the tape will be easier to apply.
Add Comment
