3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Geometric Cut Paper Table Lamp
Step 7Final Assembly - Part 2
Now that the paper is attached all around the base, begin to secure the vertical seam. Put one hand inside the lamp and one outside. Starting at the bottom attach the two sides. The flap will be on the inside and the edge of the other piece should be just shy of the corner. Continuing adjusting, attaching, and pressing the pieces together until you reach the top. Hopefully you will have a nice straight seam.
Place the lamp on it's back with the flap towards the ground and the wire just off the edge of the table. Now press all along the seam to get really good contact. Press around the base to attach the paper firmly there as well doing the top edge, then rotating 90 degrees all the way around.
Stand the lamp up and look at it from above. If it is not square you can firmly, but gingerly, adjust the folds until it is.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:drips
