All you need is plastic and a heat bender. Luckily, i have access to a heat bender at TechShop in San Jose, CA.
As a note, you should always do a test to make sure that your plastic can be heated and formed. Some plastics like poly carbonate with show black specs when heated, and these will not go away. In addition, I do not recommend heat bending material more than 3/8s of an inch thick.
Anyway, you have to bend plastic, and you want to do it right, so this is the place for you! Now, onward, to the instruction!
Remove these ads by
Signing UpStep 1: Prep! Removing Protective Film and Marking the Plastic for Meassurment
The easiest way to mark your plastic is to use a sharp knife. Carefully mark the areas you want to bend with a light scratch. This scratch can be buffed out, or will normally just melt back into the plastic during the heat bending process.
Visit Our Store »
Go Pro Today »
We built all kinds of things, wind tunnel, demonstration NMR rig, simple EDM machine (from plans in Popular Science), etc. I even remembering getting a 5lb vial of Mercury and letting my younger brothers play with it on the kitchen table. Eventually we made a barometer out of it. ...
All the kinds of things CPS and OSHA and HAZMAT teams would be all over us for these days. ... My sons cub scout leader would be hauled away today for using a 'trick' with brake fluid cleaner to start a fire these days (it generates sarin gas when heated near burning as it's default break down, so never use break cleaner to clean metal before or after welding while it is hot. I have heard from a couple of welders that had a close call and permanent neurological damage by accidentally doing this. Carburetor cleaner is OK, just not brake cleaner.)
