Get IR Keypad Value by Linker Infrared Receiver on PcDuino
2,024
16
Posted
Introduction: Get IR Keypad Value by Linker Infrared Receiver on PcDuino
1 x pcDuino V2
1 x Infrared Controller  *1
1 x Linker Infrared Receiver Module
Several Jumper wires
Step 1: Wiring Diagram
Linker Infrared Receiver  VCC  => pcduino +3v
Linker Infrared Receiver  GND =>  pcduino GND
Linker Infrared Receiver  OUT  => pcduino D11
Note: You can use  Linker base Shield for easier connection.
Step 2: Installation
Install relevant software
$ sudo apt-get update && sudo apt-get install pcduino-linux-header-3.4.29+
$ git clone https://github.com/liaods/modules
If you did have git, you need to install it first.
$ sudo apt-get install git-core
compile
Compile the downloaded file mod
$ cd /home/ubuntu/modules
$ make M=`pwd` -C /usr/src/linux-headers-3.4.29+/
Load the infrared module
$ sudo insmod ir-keypad.ko pin=11
pin=11 means Linker Infrared Receiver connected to GPIO11, you can choose the GPIO from GPIO0-4 or GPIO 7-17. Without pin=xx, the default is 8
Step 3: Test
Receive the key value:
$ sudo cat /proc/kmsg
Source has 32 bit, for example 0xe619ff00, the top 8 bit (e6) is data code, the next 8 bit (19) is Anti-code, the last 16 bit (ffoo) is user code.
Note: The same  infrared controller has the same user code. Different controller has the different code, you can modify the remote.h file under /home/ubuntu/modules/pcduino-ir-keypad
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
This looks cool, what can you use it for?
