3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Get More from Your Circular Saw
I wanted to get more from my circular saw. I developed and made this portable saw guide based on some 3/4 inch plywood and two very straight pieces of 1 inch angle iron. It can make both crosscuts and rip cuts, if one of the angle iron rails is moved away from the other.
This saw guide requires a half-sheet square of 3/4 inch plywood (4 feet x 4 feet).
Step 1View from the front
View from the front
The blade guard has been tied in the retracted position with a piece of wire. You see a slightly tapered piece of 1 x 2 holding the switch trigger in the "on" position. This is not necessary, or even desirable, for crosscuts; but it is necessary for rip cuts.
I added a strut to keep the weight of the saw motor from causing the base to flex. I described this in another Instructable titled "Too Much Flex in a Circular Saw Base."
47 comments
1-40 of 47next »
Apr 10, 2012. 3:43 PMpepecarp says:
My circular saw is CS718-AE. I am reading your "Get More on your circular saw". I cannot see a slot on the base. Please reply as I am converting my circular saw into table saw.
Apr 11, 2012. 3:01 AMpepecarp says:
I am referring to the blade opening on the ("get more from your circular saw") 3 by 4 feet table. I cannot see any blade opening. Thank you very much.
Feb 4, 2012. 10:44 AMnotools1234 says:
Couldn't you just route two thin pices of wood to have that same shape instead of using angle iron?
May 29, 2011. 7:54 AMkleinjahr says:
Nice build. Sort of like a panel saw.
Sep 12, 2009. 2:45 AMsteliart says:
Phil B, I have tried your idea with some small modifications and it works great. I have design it on sketchup so if anyone needs the file I could send it to him. Good Work! Steli
May 10, 2011. 3:01 AMsocalcovey says:
Hey Steli
Can you send me the sketchup model. I want to build it.
Santos
Dec 3, 2010. 4:59 PMsausachef says:
Hello Steliart, I am intrrested in you sketchup file could you please send it to me? sausachef@charter.net Thanks for your help
Nov 14, 2010. 3:44 PMpageup83 says:
Hi there steliart , I'm too intrested in your sketchup file
could you please send it to me ? :)
ofir83@gmail.com
Nov 15, 2010. 8:45 AMsteliart says:
No problem, enjoy!
Sep 21, 2010. 5:46 PMgordrum says:
Steli - I'm interested in your sketchup for this project. This jig will save my butt on many upcoming projects! Thanks, Gordon (gordrum@mac.com)
Sep 22, 2010. 1:07 AMsteliart says:
No problem, on its way
Apr 24, 2010. 12:05 PMtheproles says:
I'm definitely interested in the sketchup file you've created.  That would save me tons of time and frustration.
It's surplusparadise@hotmail.com
Thanks again!
Apr 25, 2010. 2:08 AMsteliart says:
I will email the file, you may also be interested to my new instructable "The Smallest Workshop in the World"
thx
Stelios
Jan 7, 2009. 5:36 AMgentry says:
So what does it do exactly?
Jan 7, 2009. 1:05 PMgentry says:
Ah, I get it. I use a circular saw all the time, but I just follow my snapped chalk line or written pencil line and it comes out pretty straight. (It took quite a while for me to be able to make straight and/or square cuts.) I have the world's worst table saw (actually, the saw itself is kind of OK, and I have a good Freud Diablo blade on it, it's just the world's worst fence -- the handle is a rusty old 6" screw and the whole thing sticks and jams when you try to move it) and I use that when I need something more precise than a handheld circular saw. I got the table saw for half price because it was the hardware store's floor demo and was missing the handle for the fence, so it was something like $100, and it's just one of those tabletop contractor table saws, not a nice big woodworking one, but I can generally make what I want with it. So on your rig, you must have to adjust the saw depth so that it doesn't cut the plywood base? I didn't quite get how that worked from the pictures, but I'll re-read it. Maybe a video of it in action would make it clearer to me. It was already clear how to put it together, I just didn't know how you would use it. Thanks!
Dec 16, 2010. 11:58 PMpfred2 says:
I never liked the fence on my grandfather's tablesaw much so I made a new one:
http://img175.imageshack.us/img175/8803/auxfence.jpg
Pimpin!
The secret of how it works:
http://img19.imageshack.us/img19/453/camq.jpg
Build pic:
http://img571.imageshack.us/img571/2234/fenceside.jpg
It cuts materials perfectly straight:
http://img195.imageshack.us/img195/2033/shelfy.jpg
(made from a full sheet of 3/4 plywood)
I'm just not seeing anyone chalk lining those cuts.
Nov 14, 2010. 8:30 PMbo88y says:
Even if you're not a carpenter, it can be worth spending some extra cash on a better saw. Those old B&Ds gave a lot of people access to saws they might not have otherwise bought, but a good Porter Cable, while still noisy, doesn't make the shrill shriek that the old B&Ds make, a shriek I find so unpleasant by comparison that I've found myself using a handsaw instead, just to avoid the noise. The P-C is also a lot more stable and balanced, and doesn't dance around on top of what you're trying to cut while you're trying to guide it. This can make a big difference regarding the ease with which you can make a straight cut, expecially on sheet goods, which this jig seems to have been designed for. And never underestimate the utility of a couple of c-clamps and a metal straight edge to clamp a fence right to the piece being cut, another practice that's made easier with a more stable saw. (Though support the sheet well-- if the sheet sags, the saw foot can slip under the guide, and oops!)
And get a good blade, a Marathon or a Diablo.
You can also get the P-C in a left-handed model.
If you want to save a bundle on power tools, go to cpooutlets.com for refurbished tools from a bunch of major manufacturers.
Nov 14, 2010. 4:18 PMhonorman says:
I made one like it out of scrap wood I had, just a little smaller like 30"x 30"
no metal, to cut Vinyl siding for a house, a lot of siding as it was a 2 story with a lot of corners, worked great
tossed it when finished.
Nov 14, 2010. 8:39 PMbo88y says:
Job-specific jigs come in handy, especially because you can make them only just as big as you need for the material you're cutting. Years ago when I was doing a lot of siding, we'd make up smaller versions of jigs like this for cutting clapboards out of a 2x8 and scraps of pine, small enough to mount on the safety-rail brackets of pump jacks.
May 23, 2010. 5:20 PMthenuttybolt says:
Great instructable. Thank you. Did you ever have a problem with the saw blade trying to pull up the piece being cut ? In normal operation the angle of attack is such that the blade draws the piece being cut against the baseplate. However, here there is a gap between the baseplate/rails and the piece being cut and hence nothing to hold it down unless you are clamping down the work piece?
Sep 20, 2009. 7:27 PMehmbee says:
Wow, I wish I had seen this before I shelled out 200 bucks for a Eurekazone saw guide, though I'm satisfied with mine. I'd be more satisfied with 200 bucks in my pocket, though.
Mar 3, 2009. 11:19 AMmarcward86 says:
whoa, i have the same square as you. i got it from an antique tool dealer in dallas.
Feb 24, 2009. 6:32 AMJoão Mamão says:
Excelent post, congratulations
Jan 13, 2009. 4:55 PMCrouchingFather says:
If you could make the saw so that it slides on a tract and so you can tilt the table to a better angle so you could just slide the wood in would make it easier. (Think about the saw they use at Homedepot and Lows to cut ply wood!
Jan 9, 2009. 9:25 AMzeel says:
Great Instructable.
Jan 6, 2009. 5:36 PMGoodhart says:
Whoa, I love making jigs, and this is going to be very useful. Thanks...
1-40 of 47next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
475
Author:Phil B
I miss the days when magazines like Popular Mechanics had all sorts of DIY projects for making and repairing just about everything. I am enjoying posting things I have learned and done since I got my...
more »
