Introduction: Get Rid of Frizzy Hair Before Making Any Hairstyle
Fixing the frizzy hair is one of the foremost objects we have
to do before going to adopt or make any hairstyle. It is the most challenging work ever. However, be on safe side and embrace some unique and easy to do tips to get rid of frizzy hair. It will consume a little time but it will give you the best result. Having the bouncy, shiny and silky hair is the desire of every girl so here I would share some home remedies and treatment on how to tame frizzy hair fast.
Step 1: Why Hair Becomes Bushy and Frizzy?
Hair is a soft thread like structure which is made of
proteins. When you give them heat in excess quantity it starts to become hard.
When you go out of the home and spend you’re a lot of time in sunlight the sweating coagulates the pores of hair roots and the dirt and humidity make them hard.
Further, when you use dryer and iron and other electric instruments to make your hair stylish and give them a trendy look temporary, it causes side effects which later turn into the hardness of the hair.
Step 2: How to Tame the Frizzy Hair?
Not necessarily you will have to use oil massage daily. Yet,
you will have to keep your hair oily for one night in a week or two hours before washing or cleansing the hair. Generally, the olive oil considers the best when it comes to reduce the frizz from the hair.
So, you can take olive oil and do massage once in a week, it is recommended if you use oil treatment twice to thrice in a week. Because, the more you nourish your hair, the most fine version of your hair you will get.
Apply conditioner on your hair after every time you shampoo. You can also take the remedial treatment of home, like; take yogurt and egg mask once in a week. It is a natural mask
Step 3: Treatment With Apple Cider Vinegar
An apple cider vinegar gives a great deal in handling the
frizzy hair. You just need to take two to three tablespoon of this vinegar and then add it in the two cup of water. Pour that water on your hair that it covers all you hair.
Rinse your hair normally with chilled water. It will not only cure the frizz but also will give extra shine to your hair.
Use this treatment once in a week
Step 4: Care Guide
• Use the shampoo
which has the mild chemicals that will not snatches moisturizer from your hair.
• Always use the comb with the wide tooth as it will prevent your hair from falling.
• Try to save your hair from extreme and harsh weather conditions, like heavy acids rain, bright sunlight and humidity by using scarves and anything else suitable.
You can get more guidance for your hair care on the www.fashonik.com platform.
Last but not the least, remember all the above-mentioned instructions and follow them carefully and perpetually if you want a better result. Your consistency matters a lot. These tips will help you a lot to get rid of frizzy hair before making any hairstyle.
Frizzy hair is the worst!! Thanks for sharing!
