Get Six 1.5V Cells From One 9V Battery
17,523
61
20
Posted
Introduction: Get Six 1.5V Cells From One 9V Battery
Did you know that the common Alkaline 9 Volt battery is made up of six 1.5 Volt cells? This is very useful if you need small package 1.5 Volt supply for a project.  The independant cells are just slightly smaller than AAA cells.
Warnings and Stuff
Do not try this on rechargable batteries of any kind as the potential for explosion is higher.  With an Alkaline battery this instructable is quite safe, but still take care when separating the seam of the outer metal package.  Do not use power tools to disassemble. Also, watch your fingers on the metal packaging as this can cut you if care is not taken.
Hacking the 9 Volt for it's Prize
Check out the photo's to see the disassembly steps.  It goes, pry end crimps at the seam.  Then pry the seam open and remove the shrink wrapped cells. Now cut open the wrapping.  Finally, cut the metal tabs that bind each cell together.
You're done.
Final Notes
Notice that when you disassemble everything you also end up with a 9 Volt battery connector?  This in itself is cool.  Check out member Joshmt2012's instructable https://www.instructables.com/id/Free-9-volt-battery-clip. He provides a great instructable on this.
Check out the last picture.  This is from a cheap 9 Volt battery.  Very different way of arranging the cells. I have never cracked one of these open so I don't know if they can be separated.  My feeling is they are held intact by the outer fused shell. Eventually I'll give it a try and post an update here.
Further note, the more popular brand name batteries use the six cells as shown in the main photos. These are the ones you want.
Was this a useful electronics lab tip?  If so let your voice be heard and vote for it in the Electronics Tips & Tricks Contest. I thank you for your vote and support. About contest voting: The voting button can be found at the top of this instructable and you can vote for more than one Instructable in each contest. If you read an instructable you like, any instructable, show your gratitude with a vote.
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    20 Comments
    HELP!!!! I TRIED TO PULL APART THE BATTERY WITH MY TEETH AND I THINK I JUST SWALLOWED BATTERY ACID......WHAT DO I DO???!!
    PLEASE HELP
    if your still alive, your obviously fine
    Before i injure myself attempting this, is it real?
    Yup, it's very real. Just as shown in the photos. The only step to watch for injury is in taking off the outer shell. It's sheet metal and therefore the edges can cut if care isn't taken. Leather work gloves can protect hands from such cuts.
    Ok. Im just making sure it wont pour acid all over my hands.
    Oh, and there's no oily or waxie residue as some might suggest. Well, at least not in the twenty or so batteries I have taken apart. Also, shrink tubing the cells is not necessary. Just saying.
    This works great in case of an emergency!
