Get Up and Move!
706
6
Posted
Introduction: Get Up and Move!
A wearable ouch that vibrates if you've been sitting down for too long.
Step 1: Materials
Adafruit Gemma
Battery case and batteries
Photoresistor
Vibration motor
Resistor for photo sensor (brown orange black) 10K
resistor for vibration motor (red red brown) 220k
PN222 Transistor for vibration motor
1N4001 Diode for vibration motor
Cushion fabric to hold the circuit
Thread and a whole lot of solder
Fabric for pouch for battery case
Clip
JST connector to connect to the battery
Heat shrink tubing
Tears (not pictured)
Step 2: Get the Easy Part Out of the Way
The first thing you're gonna want to do is attach the 1N4001 diode to the vibrating motor. Just remember, the red wire should be attached to the cathode (the side with the stripe. There, I saved you a google.)
Step 3: The Circuit
I used a modified version of Becky Stern's Mindfulness bracelet from Adafruit's learn page and added a photoresistor and some different code.
Step 4: Prototyping
Now, I know we already soldered stuff, but that would have been attached anyway and it's easier to connect them this way. Also note: in this image you can see that there is a little sticky pull away strip on the back of the motor. Very useful.
Step 5: The Code (dramatic Music)
This is the code to the universe. Just kidding , but it will tell the arduino what to do so..
const int motorPin = 0;
int pr= 1;
int dark=15;
int lvl=0;
void setup() {
pinMode(motorPin,OUTPUT); }
void loop() {
lvl = analogRead(pr);
if (lvl < dark){
digitalWrite(motorPin, HIGH);
delay(1000);
digitalWrite(motorPin,LOW);
delay(10000); } //you can edit these numbers (the're in milliseconds) to make the time different
//it's recommended to get up and move for about twenty minutes after forty minutes of sitting down
Step 6: Almost Done!
This is what the finished circuit should look like. Just sew the edges of the cushioned fabric to the pouch and sew the circuit down.
Step 7: Attach the Clip
Once you make sure that your circuit works, glue the clip to the battery pack.
Step 8: Wear It!
I added a few little bits to make it interesting. If you know you're going to be on the computer a lot, just clip this on so you will be reminded to move every once in a while. Have fun!
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
2 Comments
That's a good idea :) Since I work on the computer I need reminders to stretch so I don't get too stiff!
Yeah, it's important for your eyes, too so they don't get tied or worn out. I can get migraines if I stay on the computer for too long.
