On one side, he has a nasty tummy ache. On the other... BIG SACK OF SUNSHINE!
Let's get going.
Remove these ads by
Signing UpStep 1Design and Patterns
Here I've shown the patterns I used. You don't have to use the same design. In fact, it's even better if you come up with your own!
Some tips:
- Draw out the design full size on a sheet of paper. Cut this out and then trace around it with roughly a half-inch (~1 cm) margin onto card stock or, as in my case, some file folders you liberated from your corporate place of work. The margin gives you some comfy-room while sewing and helps account for the fact that your guy will end up a bit 3D.
- One pattern is used for both the front and back halves. You just flip it over :)
- Take good care of your patterns. If you don't like the end product, you can go back and make changes to the patterns in the problem areas.
- You can use a single pattern for multiple parts, if applicable. I did this for the top of the head.
For colors, I chose a sickly palette and a happy palette. Make sure you have enough fabric before you start. Also take note of which is the "right" side and which is the "wrong" side. Fleece may seem like it's the same on both sides at first, but there are usually subtle differences that make one side preferable.
4
comments
Add Comment
Sunbanks
says:
ChrysN
says:
Add Comment
