3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Get Your (Mini) Bike (Trike) Ready For Spring
Here are some tips for getting your 2 (mini bike), 3, or 4 wheel go kart up and running for the season.
Maybe you don't have a go kart. Why not build one? Here are some other instructables on how to build yourself your first kart:
Make your own Go-Kart.
Design and Make Your Own Go-Kart
It doesn't matter how many wheels it has, it doesn't have to be a 3 wheel like mine, it could have 4 wheels or even 2 (mini bike), the same basic principles apply.
Stay tuned because the engine section applies to any small engine, like what is found on lawn mowers, pressure washers, generators, etc.
Step 1Brakes
Brakes
Arguably the most important feature when using your kart is the ability to stop. Before you forget about it, check the break hardware first.
Pull the brake lever(s) or push the brake pedal (left pedal) and try moving the kart. You shouldn't be able to move the kart and have the wheels with brakes on them turn. Also check for "slop" in the brakes. The brake should engage when the lever or pedal is just moved a little bit. If you have to pull the lever almost all the way to the handlebar or push the pedal almost all the way down, your brakes need adjustment. Hydraulic brakes are self adjusting. You can tell if you have hydraulic brakes if there is a reservoir for adding brake fluid.
To adjust a brake lever, unscrew the cable retainer from the lever a little bit and try the brake again. The retainer is the green thing in the picture below. You should need pliers when you first start unscrewing the retainer. You might have to unscrew the lock nut in order to get it to turn freely. When it's adjusted right, the brake should fully engage by only pulling the lever a little bit. If the retainer unscrews all the way, this is a sign that you either need new brakes or they need to be adjusted down at the caliper/band/drum. If you don't know what you're doing down there, take it to someone who does. The health of you and/or your children is more important than a couple bucks saved by doing an adjustment yourself.
To adjust a brake pedal on the 4 wheel karts, follow the rod linkage from the petal to where it ends. There should be some threads and a nut there. It should be apparent now how to do the adjustment. If it isn't, take it to someone who knows what they're doing.
You'll also want to check the amount of brake material on the pad/band/shoe(s) that it isn't below the wear indicator or isn't excessively worn. Again, I highly recommend taking it to someone unless you've done brakes before and are confident with your own work.
25 comments
Aug 29, 2010. 5:09 PMquadracer says:
For gaping your plugs, IMO It is more important to have the ground level to the electrode, And to check for wear on the porcelain, rounded edges, cracks or chips are overlooked. Good Ible
May 4, 2009. 5:09 PMfrankfarms says:
NICE! This might seem like no big deal but I have the exact same schwinn grips on my bike
Apr 20, 2009. 5:29 PMcody316 says:
how much hp does the engine have, you have for yours?
Apr 25, 2009. 3:40 AMNX13 says:
how much did the engin cost
Apr 16, 2009. 9:39 PMbattlebotrock says:
nice go-cart. This summer I will learn to weld. Then after learning to weld I am going to build a go-cart but it will be a street only. I already have my engine. It is a Honda Civic. It will be my first time making a go-cart but my dad will be able to help me.
Jan 12, 2009. 5:36 AMcartster says:
well acually heres a vid i might try to ollow with but you can guys can also look at it too.
its the link at the tp of my mesage
Jan 12, 2009. 7:14 PMcartster says:
i didnt make it but now my dad says that we wont build it! so i am goeing to make some thing different but ohwell
Jan 12, 2009. 5:33 AMcartster says:
realy nice trike man, but how do you acually build it?
Dec 19, 2008. 6:43 PMCoati says:
That is definitely the coolest go cart I have seen in a while,and a great instructable.
May 29, 2008. 5:47 PMnitrox027 says:
how much would it cost to build one of those
May 30, 2008. 4:51 AMnitrox027 says:
thanks
Jun 29, 2008. 12:30 PMnitrox027 says:
do you have a building plan for the frame? I totally want to build one of these how big is that motor and where can i find one
Jun 12, 2008. 4:34 PMpackman says:
dude this is tight can you tell me were you got the trike i just dont like reading long stuff thanks
May 26, 2008. 2:27 PMsotsirh194 says:
I am thinking about building a simple go kart and I have a few questions. 1) Are they belt or chain driven? 2) Can a lawn mower enginr power it?
May 2, 2008. 8:37 AMll.13 says:
Nice go-cart!
May 2, 2008. 5:26 AMLinuxH4x0r says:
Good tips!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:The Lightning Stalker
