Get a 3 Volt Relay From a Polaroid Camera
Published
Introduction: Get a 3 Volt Relay From a Polaroid Camera
This whas made for fun with my "portable tool box" as a demonstration for my frends. The ideea came when i found a smashed Polaroid camera (name is not important but is a self developing foto camera - at the end of the cycle it spits out your picture on a small secial paper).
First i whanted the flash from it but got no luck, the bulb whas cracked in 2 parts :P, then i got the ideea of playing a lil wit that thiny elecromagnet that whas in ...
Note : the relay is made from scrap in 10 minutes, i know it shud be more "professional" done ...
Step 1: Parts and Tools
I used a cutter, a surgical clamp (lol i realy dont know the name but is very handy), hot glue gun, a dremel, soldering iron, a sharp made pice of metal ... a screwdriver filipps head ( aka cross or "x" shaped head).
Ohhh i almost missed to tell you need 2 hands that are not shacky ...
All parts you need are in the camera even the wire ...
1 x Elecromagnet
1 x 0.5cm long spring ( u get a lot of them from the camera, use 1 suited for your application)
1 x Screw (i used a PC case one i had it on my desk)
1 x Metal part attached to plastic (the white triangle with a gold spring on it)
4 x Wire ( -.- you know wire ... right ? )
1 x Plastic case (i used a old box that i found laying around in the basement)
Step 2: Build the Second Circuit
Get all screws out and get all the mechanical parts out and u will get a 10cm x 2.5cm metal plate with a mobile part of the elecromagnet and the elecromagnet itself.
Now use the dremel to cut the plate to a more handy form (my is 2.5cm x 2.5cm).
Some theoretical knowledge :
All relays have at least 4 connectors :
2 connectors for control of the coil - the control circuit
2 connectors for the switch - the switch circuit
This relay is switching on when the coil is powered, but can easly be moded to switch off when powerd.
Now you need to put the outher part of the spring on the silver spike that comes out from the movable part. The easy part is done, now carefully get out the coil from the holder then put the spring on one of the pins from the "fork" that hold it on place and then put it back in place. Use somthing to keep the distance between the elecromagnet and the movable part at around 1-1.5mm
if you use weak power (i used 100mA and worked VERY well). Solder the cables now, 2 yellow for the coil and the orange as folowing : 1 at the gray metal frame (scratch the gray stuff with the cutter and the solder the cable there) the second orange cable to the gold spring of the white triangle like plastic pice.
Note : i know is hard to understand but this is my first instructable and i finished the project before i knowed of this sites existence -.-"
Step 3: Tune the Relay
Thats is the part where you need a "calm hand" .
1. put the coil under power (3 volt)
2. move the white triangle until the gold spring attached to it GENTILEY touch the silver spike from the movable part of the relay.
3. cut the power of the coil and check to see if the contact is broken
4. if all went OK then you can now hot glue it to a box, but be VERY CAREFULL not to disturb the touch pads when you fix the screw that holds the white triangle in place (check it again after you do that) then you can go to the final step ...
5. find a box and fix it in (i used hot glue to fix my).
    • Make it Move Contest
    • Microcontroller Contest
    • Woodworking Contest
      Woodworking Contest
    6 Comments
    lol it is how to make a relay with the pices you get from a polaroid camera, it is for fun and to learn how a relay is build and how it works ...
    I uploaded better pictures ... hope it will help ...
    Really sorry about the pictures ppl, im using a Sagem my511x and that camera is REALY BAD i used a flashlight in a well lighted place to get them look acceptable ... i will try to borrow a better camera and redo the pictures ... Yes it is a Single-pole/single-throw switch.
    You need to learn to use the macro-mode on your camera. There is an instructable on that for camera phones too. I'm guessing this is SPST?
    Pictures...terrible!!!!!
