3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Get Over a Barbed Wire Fence
Step 4Climb over it (with protection)
  • last photo ←
The best method of quickly making your way over the fence without leaving a trace of your presence is by using a barrier between yourself and the barbs. This will minimize your chances contracting fence-AIDS.
There are many materials which can be used to protect yourself from the barbs. Some of the more popular ones include thick cardboard, anything made of leather (jackets, pants, etc.), sleeping bags, carpet, and the bodies of comrades.
The following movie clip (I would name the source, but the first two rules prohibit me) shows an example of using old carpet to quickly bypass a barbed wire fence while leaving no trace of their presence.
The old carpet / rug method is perhaps one of the best ways of getting over a barbed wire fence. The weaving on the bottom of the fabric is extremely thick and does not allow the barbs to pass through, protecting the user from any harm. To be extra safe the carpet should be folded over itself at least once to ensure no barb penetration. The pictures below show the process of cutting up an old rug and using it to protect me from the barbs while I climb over the fence. The process and all the pictures are pretty self-explanatory.
There are only two interesting things to note about the pictures. The first is that I somewhat cheated by going with the angle of the barbed wire fence instead of against it. The second is that the rug/carpet will be a much sturdier climbing surface if it is placed over an angle bracket.
24 comments
Mar 16, 2008. 7:59 AMstock_market says:
EXCELLENT!!
Although I would never want to try Constantine Wire, which is nothing but razor blade material, which is what all prisons use now. Also, in prisons they have these other easier to climb over wires before the Constantine that sets off alarms, probably a row of 3, that have to be climbed over.
The only way is like in 'Prison Break' with Michael Scofield, who tattooed the Prison Blueprints on his back. Or do what the majority of prison idiots do, and hop out of a laundry truck in the laundry.
Nov 1, 2011. 12:44 AMArcticNemo says:
Concertina wire may be barbed or razor-type. The name comes from the coiled configuration, after the musical instrument. The loose coils offer far less support than a tensioned line, but you need more wire to cover a given distance.
When placed two or three rows deep on the ground, it becomes an effective barrier to foot traffic...and yes, ninjas and Marines aren't bothered by it.
Mar 21, 2008. 4:28 AMstock_market says:
Everyone calls it Constantine, and I will always know and love it as Constantine.
Jul 1, 2008. 4:58 PMRoflolommo says:
concertina wire is sometimes mistakenly called, sometimes by soldiers and marines constantino wire. "Constantino" probably came from a corruption/misunderstanding of "Concertina" and led to confusion with the Roman Emperor Constantine. thats from the wikipedia article so sorry man but your wrong anyway you should be mistakenly calling it "constantino" wire not "constantine" wire
Jul 8, 2008. 9:31 AMsephiroth9393 says:
don't listen to wikipedia about everything
Aug 5, 2008. 6:41 PMRoflolommo says:
0.0 you take that back
Aug 6, 2008. 11:58 AMsephiroth9393 says:
wikisucks
Jan 26, 2009. 3:26 PMTobita says:
FF7 sucked. 2 (US 1991) was perfect though XD.
Jan 29, 2009. 5:54 AMsephiroth9393 says:
you like living with mom and dad?
Jan 29, 2009. 1:56 PMTobita says:
I'm f14, i don't really have a choice other than maybe living with cousins and uncles or go to foster care. It's not too shabby either!
Mar 20, 2008. 7:05 PMtebben says:
Check out Rangerfan's post with the wikipedia article. There is no such thing as constantine wire. It's concertina wire.
Jan 7, 2011. 10:08 AMBatmanProject777 says:
One additional little detail, which may help set your mind at ease, if crossing a razor wire fence still seems hazardous, even with a carpet......get on youtube, and watch bears fight. Consider that super dense fur they've got....one would think they also have such amazing strength, and terrifying claws, and should cleaver right through each other, sending chunks of flesh flying everywhere....but you mostly see little cuts emerge (little, all things considered) and some bits of fur getting ripped off. Summary; against knives and claws, fur is great armor !
Jan 7, 2011. 10:03 AMBatmanProject777 says:
NOW, HOW TO CROSS RAZOR WIRE ? I'd think it's not a whole lot different. I'm not sure just how sharp the stuff is, but I do own a handful of knives. In my humble experience, knives almost never cut anything until the object placed against the blade is moved, allowing the micro serrations to do their work....those serrations are exactly like saw teeth....you've gotta move a saw to cut with it. The exception is a razor blade....however, with using a carpet, the thick material on underside is usually just like hemp rope or twine. Raise your hand if you've ever tried cutting a thick rope with a razor blade...it can be done, right ?.....still, works much better when the blade is moved. Now imaging placing a blade against two layers of carpet.....you've got that tough underside layer, then a thick dense stack of fibers (the carpet fibers). Yeah sure, the razor wire will probably end up having cut a little of it once your done and loooking over it to see, but cutting through it while climbing over.....not real likely.
Jun 27, 2009. 6:15 PMdavidemil55 says:
first is do not talk about fight club second rule is you DO NOT TALK about fight club Love that movie
Oct 3, 2008. 1:01 PM11010010110 says:
Big A shape ladder thats it !
Sep 2, 2008. 5:47 AMrealcelestialphoenix says:
(removed by author or community request)
Sep 16, 2008. 7:24 PMdougwtt779 says:
you can just use a crap t-shirt
Sep 17, 2008. 10:20 AMrealcelestialphoenix says:
Sep 23, 2008. 3:38 PM=SMART= says:
lol
May 22, 2008. 12:51 PMmrpages says:
I'd like to see examples of the things you left out, like climbing the angled barbed wire fence. You describe using your upper body, but then don't say anything about how. You also don't demonstrate climbing the wire against the angles, which will likely be the most common way. Demonstrate the difficult ones, not the easy ones. That's what people want to learn.
Apr 4, 2008. 5:29 PMxylo0 says:
Hey, dude. I just escaped from prison. Now I can go burninating the country side.
Apr 25, 2008. 10:50 AMDerin says:
do they have computers there
Mar 25, 2008. 4:52 AMferdilouw says:
I've just erected razor wire around my house and our small community to keep the unwanted nightly visitors (a.k.a. robbers/murderers/rapists) out. In South Africa palisade fencing topped by devils fork is not effective anymore. Now we are adding electrical and razor wire on top of the existing fences. All of us erecting the razor wire shed some blood in the process, but we can still see ways to breach our security. The big question is to identify the weakest links and decide how much money and effort to throw at it.
Apr 22, 2008. 11:30 AMVelotrash Industries says:
if you want to find weak links, look yourself in and release 10 or so wild dogs. trust me, you'll find the breaks very quickly.
Mar 24, 2008. 3:50 PMautonomousoperations says:
ill vote for this when you add the section on razor ribbon
Mar 22, 2008. 5:32 PMUniquenikasy says:
If you were gonna juz use the old carpet technique, what was the use of the ones before it??? Anyways, the old carpets the best, leaves no trace, but id suggest making something to conceal it... say sew the old carpet to an oversized jacket or something. Your tutorial only shows how to get over the fence, not what happens next. Good one though, but we all, even in Malaysia, knew how to do that since we were 7. From my experience, getting through the fence is much easier than getting over it
Mar 17, 2008. 11:09 PMpoeticoddity says:
Correct me if I'm wrong, but you posted both photographs and videos of you trespassing into a naval base, didn't you? You might want to cover your face for these sorts of things, or at least blur it in the photos. Still a nice tutorial, though.
Mar 21, 2008. 5:02 AMTrent The Thief says:
He's already on the base. The fence he climbed is next to the tower. It's a so-so instructable. Most kids I grew up with already knew how to do that by 4th grade, though. It's a little trickier when the wire is tilted out on one side or both sides.
Mar 20, 2008. 10:04 PMkamathln says:
Excellent article.. Unless the fence builders thought some electrifying experience will make your life more thrilling. ;-)
Mar 20, 2008. 4:16 PMGneekman says:
Nice use of humor; I appreciated it!
Mar 18, 2008. 7:47 AMZero_FactiX says:
Yes i agree with the it's not so bright to break into a naval base comment maybe somewhere a little less Goverment regulated might have been a better idea haha.
Mar 14, 2008. 6:14 PMkfrantz54 says:
What movie is that?
Mar 14, 2008. 6:49 PMPyrowuzzup says:
fight club. you are not your clever instructable.
Mar 15, 2008. 9:43 AMJ_SCAP says:
hahaha but always remember you arent your bowel cancer you arent your chachies :)
Mar 15, 2008. 9:12 AMglinion says:
wow you've cramed one hell of a lot of information into a fairly simple instructable! Cool
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
331
Author:Tetranitrate
I'm attending NYU-Poly.
