3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Get project buckets for free!
Get 5-gallon plastic project buckets for free, keep them out of landfills.
To see my related Instructables, click on "unclesam" just below the title above or in the INFO box to the right. On the new page that appears, repeatedly click "NEXT" to see all of them.
Unclesam
Step 1Food-grade pickle buckets
Chain hamburger joints get their sliced burger pickles in sturdy food-grade 5-gallon plastic buckets, and these buckets cannot be reused for their original purpose. You can use the buckets to tote and store things in the shop, cut and shape them as parts of projects, or make a wooden rack that holds rows of buckets on their sides as wide-mouth storage bins for tools, components, materials. They are useful to crafters, farmers, gardeners, homeowners, boaters, the list is endless. These buckets are more sturdy than similar ones sold at hardware stores for $4 to $6 each, and the pickle buckets also have a snap-on lid. (Photo shows soft black seal ring on underside rim of lid). A busy burger joint will empty one to three buckets a week, depending on the season. It is inconvenient for most small businesses to recycle the buckets, so they get thrown into the business' dumpster, then go into a landfill. The plastic could be recycled, but reuse is more efficient, and it actually saves the business manager money to keep the buckets out of his dumpster.
I regularly visit a nearby chain burger joint, and its manager has his buckets rinsed and set aside for me to pick up when I drop by. I offer them free to friends and neighbors and to a charity that helps local folks. You could do the same in your neighborhood, or just get a few for yourself. Bakeries, donut shops and the cake departments of grocery stores also get ingredients in buckets, and they are all much easier to clean than buckets used to ship paint and drywall compound.
81 comments
1-40 of 81next »
Mar 25, 2012. 6:37 PMDsanders2014 says:
How do you ask for them? So I am not rude
Feb 7, 2012. 3:25 PMTakelababy says:
I place a new white "kitchen catcher" inside a plastic pail then I don't have to worry about what it held altho I will still give it a good soaking in bleach water first.
Aug 10, 2011. 5:31 PMsplazem says:
Sweet!
Jun 26, 2011. 10:28 PMSIRJAMES09 says:
even buckets that once had clorine pucks can be use for food BUT, you need to run water thru the bucket for about 30 minutes(minimum-I preferr 1hour) and use HOT water. after that, Scrub out the bucket really good with soap & water. if there is no clorine smell after this, you're fine, BUT if you smell clorine scrubb again & again till there is no smell.
this I learned from experience.
Jul 21, 2011. 3:13 PMSketch98 says:
I'd rather buy a new bucket, it would even be cheaper than half an hour of warm running water.
Jun 15, 2011. 5:05 PMw0x0f says:
If you don't need food-grade buckets, check with your local swimming pool. Our pool uses a solid chlorine puck system and the pucks come in a 5 gallon pail with a screw on lid. I wouldn't use these for anything food-related, but they're clean pails that only need a rinse before you use them. Try not to breathe in any of the dust that may be in the pail, it's not good for you.
Dec 18, 2009. 10:23 PMfragile.ecstasy says:
I'm thinking this might be good for holding my son's cloth diapers. Will have to see if I can scrounge some up.
Jun 13, 2011. 4:19 AMpaulo500 says:
That's exactly what we use for our cloth diapers. Works perfectly.
Jan 7, 2011. 7:36 AMKevanf1 says:
For anybody in the UK try your local supermarket. If the supermarket has an instore bakery ask them for any empty jam buckets. I've had some really useful square shaped 5 gallon buckets from my local Asda store.
Good 'ible' and useable worldwide.
Take care.
Kevan
Jun 12, 2011. 12:26 PMScattyCrafter says:
Ooh thanks for the idea in UK often I need buckets for storing my craft things .
Jun 12, 2011. 1:08 PMKevanf1 says:
Pleasure to help out :-)
Apr 29, 2009. 11:37 AMhopit says:
I've found these buckets in market dumpsters while rescuing discarded good food and other items. They've proven useful or putting compost scraps and using in the garden to store mulch, etc. It would make a lot more sense for the stores to return the buckets to the vendor to be refilled. If all the discarded buckets were actually put to other uses and not thrown out, before long everyone would have more buckets than we needed and would have to throw them out because we don't have a place for them. The only sustainable society is a zero-waste society. Otherwise we'll use up our resources and filling up our land with trash heaps.
Jun 12, 2011. 1:00 PMScattyCrafter says:
Yes BUT if every supplier took back the buckets to send back to the supplier of those then it would work.
I remember the days when we used to take our 'empty glass bottles of soda' back to the vendor for recyciling( probably re-use ) and we would get 2 old pennies or even 3 for each bottle.
Some children made up their pocket money by going around collecting discarded bottles :-)
why can we not do that now?
May 13, 2009. 10:48 AMhopit says:
Yes, there are issues in reusing the buckets and they should be addressed. With our current system our toxic landfills are growing and raw materials are getting depleted. We've got concerns about sanity on one side, and the desire to not trash our planet on the other. Which is more important?
May 5, 2009. 8:15 AMluvit says:
i once looked for food in the dumpster on a hot day. it was a bit cooler in the dumpster, so i took a nap.
May 3, 2009. 8:58 PMRustar says:
I work at a Wendy's and our pickles come in bags. My mom however buys kitty litter in huge plastic buckets; now every time the plumber comes over she gives him some and he knocks off a couple bucks.
Feb 12, 2010. 9:58 PMabbyadams says:
I got some surplus square-sided buckets dirt cheap. They were meant to hold a lot of cat food, but they'd never even been used. I guess the company was changing the design. Anyway, now I have white translucent wastebaskets in every room. Plus, I left the handles on, so in a pinch they're still buckets.
Jun 12, 2011. 12:31 PMScattyCrafter says:
Also easy to pick up to empty them :-)
May 7, 2011. 12:50 PMeulaliaaaa! says:
We own a vineyard, so we need buckets to put the grapes in. When we need new ones, we go to LeMars, where the Blue Bunny ice cream factory is, and we get free buckets there. We can usually acquire around seventy buckets for free!
Jan 29, 2011. 6:36 PMmoonchylde says:
If you're not above a little trash-picking, you could always look for empty cat litter buckets. They're usually 2 1/2 gallon square buckets, and people toss them all the time. But always be sure that the buckets are empty before you toss them in your car; I've gotten a few that were refilled with used cat litter before.
Dec 23, 2010. 6:30 PMBtheBike says:
i tried getting buckets from Safeway bakery . The baker was like "No ! We dont give them out anymore." She was kind of rude about my simple customer inquiry . I talked to the manager at check out, not trying to get anyone in trouble but just to know. I was told that people were using them to make illegal drugs with !!
They are like $1.40 at home depot but reuse is preferred over new . Plus used bakery buckets are food grade . Dam meth heads = ( Have to get an elderly person to get them for me .
Oct 10, 2009. 3:38 AMmaryshe says:
I was thinking that 5 gallon buckets would be good for Lego storage.  You could even sort by color.  They were too expensive for me so I looked on this site.  What do ya know?  I find out how to get them for free.  Thanks.  Does the pickle smell really not come out though?  Icing buckets would at least have a vanilla smell, right?
Jun 14, 2010. 9:58 PMrhaubejoi says:
Hi, I used to sell Tupperware and one of the tips they shared with us was that crumpled up newspaper left in a sealed up plastic container will help take the smell out. That was one that they told us for people that leave the leftovers in a little too long. I am sure it should work for a pickle smell too. Leave the crumpled up newspapers in there for a while. A week or two should be good.
Jan 7, 2010. 1:53 PMwillrandship says:
Vanilla buckets have a chance of exploding.....it depends on whether it's real or fake, but I don't remember which. Still though, I wouldn't risk losing my legos to explosive vanilla bombs....
Nov 30, 2009. 7:29 AMmbear says:
I wonder if you could get rid of the pickle smell with baking soda. It works in a refrigerator and my carpet. (I've even used it when the cat was sick to cover the smell so I could clean.)
Maybe mixing baking soda and water into a paste and "painting" the inside of the bucket would pull out the pickle smell.
Just a thought.
Jun 6, 2010. 7:24 AMsspence says:
For all kinds of bucket projects and discussion see http://groups.yahoo.com/group/bucketproducts/
Jun 4, 2010. 10:27 AMoscargrouch says:
hi, everyone....if you use discarded materials like five gallon buckets they can be used for many things you can construct your self...domes with tapered conical addition of recycled bottles. even space craft...... wanna help? helping get the buckets..... ::::) eric jason crews c.e.o. design desk 209 upland rd blacksburg va . email: ericcrews@rocketmail.com
Dec 17, 2009. 10:50 AMalpacasweeteyes says:
I will be checking my local McDonald's and White Castle for the buckets. I paid $4 each from an online source for brand new 5 gals.  But lets keep these guys and other plastic pop bottles and such out of the landfills and use them for gardening...yes, gardening!  These make wonderful sub-irrigated planters (SIPs) and grow just about everything BEAUTIFULLY!
For the urban gardener, these things are the answer to buying bland-tasting, brick-hard tomatoes, cukes, bell peppers, etc.
The ultimate way to be "green" and grow-yur-own too!
Pics of a tomato planted in a 5 gal. sip in my basement under an 85 watt cfl.
Dec 18, 2009. 11:31 AMalpacasweeteyes says:
What's up, unclesam?  Compact fluorescent lighting comes in a wide variety of  sizes, wattages and spectrums...the best in my opinion for indoor use are the  85 or 105 watt CFLs which come in daylight, warm white, cool white and full spectrum.  Start plants with the vegetative lights at 5000k or above and end off with "flowering" CFLs around 3000-4100k.  They use less wattage for the length of time in use than the metal halides and such, but if you really want an indoor plant room, might want to look into the 250wt and up MHs and HPSs...
I just recently moved to Brooklyn, the backyard infested with "tree rats" (squirrels) so a wired enclosure for my SIPs will be a must for the summer. You might consider that for protection against your local wildlife!
Sep 27, 2009. 9:14 AMjestertime says:
yeah pickle some alcoholic pickles they are great for football games,plays,movies and anywhere else that they need to be discrete.
Aug 26, 2009. 2:18 PMdanm95 says:
Ha ha, one time I was in a play and there was a strange smell back stage. turns out it was one of these. the realy wierd part is I was in another play and there was ANOTHER pickle bucket. we laphed and made people smell it. it was fun :- )
Jun 25, 2009. 10:30 PMthetech101 says:
You could potentially use these for rain water barrels. Thanks for the awesome Instructable. I needed some rain water barrels, but they were too expensive.
Feb 27, 2009. 3:22 PMplzspoilme25 says:
thanks for posting sometimes the simplest thing are the why didnt i do that....me i'm shy and have problems with going into places and asking for such things....so usually do without all together....
Jun 25, 2009. 10:21 PMthetech101 says:
I used to. I was able to get over it, but it took practice.
May 13, 2009. 5:12 AMzekiller2193 says:
Is this the case at McDonald's cuz I would have to go really far away for anything else?
1-40 of 81next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
69
Author:unclesam
